Question about Samsung SCH-a870 Cellular Phone
Bluetooth not recognized after pairing?
Samsung A870. Paired with Jabra bt500 bluetooth, but upon turning phone and bluetooth off and back on , bluetooth will not interact with phone. It's on the list in the settings section, but error meassage states that this device is not supported. It works fine until I shut the units off and turn back on again. I don't understand?
3 Suggested Answers
  • 7 Answers
SOURCE: how remove paired bluetooth device from samsung
first go to bluetooth menu
activate bluetooth]
select the device you want delete pairing
scroll down and click on delete
pairing would be deleted
Posted on Mar 12, 2010
SOURCE: how to delete paired devices from bluetooth in
switch on the blue tooth. touch the paired device. from the menu that appears touch delete. you have to drag it down to find the option
Posted on Sep 29, 2010
  • 86 Answers
SOURCE: i want to delete the
Follow this path- main menu-> bluetooth (its in the 2nd homescreen)-> turn on bluetooth (by tapping on the icon). This should show all the devices paired with your phone. Find the device you want to delete and tap on it. select 'delete' from the options shown
Posted on Feb 10, 2011
0 characters
1 Points
Trying to pair my iphone with my jabra BT2080. It was paired before, but now I follow instructions and it just keeps searching, screen shows the Jabra not paired then below says Now Discoverable??
Make sure the iphone is still set to discoverable mode and try again. Turn off bluetooth and turn it back on if the problem persists.
Mar 06, 2011 | Cell Phones
I'm trying to pair my jabra bt500 with my iPhone 4. I get all the way through the process when I receive the following message: Connection Unsuccessful "Jabra BT500" is not...
I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
Dec 28, 2010 | Cell Phones
I need the manual that came with my jabra blue tooth
Having the model number of the Jabra would be extremely helpful.
Most Bluetooth devices have a default pairing ID of 0000.
As for turning the volume UP or down, depending on what ear it is worn on, is nothing but trial and error.
Turn on your phone, go to settings (or tools) and turn on bluetooth. Select find device:
Turn bluetooth JABRA on and HOLD the power button until the Jabra flashes. (this means it is sending a bluetooth signal) Your phone should see it and ask for a pairing code. Enter 0000
A message on your phone should indicate you are paired.
Good luck.
Oct 08, 2010 | Cell Phones
I have a Jabra Bluetooth headset after updating my phone with Nokia Ovi Suite I lost all my games and my paired things on bluetooth. I tried 4 times to pair the Jabra so have locked it out of my phone how...
hi, you can solve this problem in a simple method- press the power button of the bluetooth device continuously for 2 or3 s check the light of blutooth device is turned on then go to bluetooth device option on your mobile phone and select add more device the time pair the device by using this code 0000
was this helpful to you
Aug 27, 2010 | Nokia 6300 Cellular Phone
Can I use a Verizon Jabra VBT 185Z bluetooth with Samsung A-177
Hai sir my cell phon is problem not ringing lcd not open
my .5610d-1
Mar 23, 2010 | Nokia 1600 Cellular Phone
Bluetooth pairing
It can only be connected to 1 at a time and you have to set it up so it won't just grab a random phone.
Aug 07, 2009 | Cell Phones
Jabra bt8040 is not pairing with iPhone 3gs
No problem. When Jabra is off, press and hold till green light turns blue. On the iPhone: settings, general, bluetooth; switch to on. It will search, then it will list the Jabra BT8040, not paired. Highlight the "not paired" line, and it will start to pair; a few seconds later, it will say "connected".
Jul 09, 2009 | Apple Cell Phones
Lg env2/ jabra vbt85z bluetooth pairing
You will have to go in and reconnect it. When it says allow, be sure to push yes. You may have accidently turned of the internal connection in your phone. Go to bluetooth menu in your phone, click the bluetooth that is yours, and click connect. I did that once, and this fixed my problem. I dont think you can have it paired to more than one phone at a time. It wont know which one to answer. Good luck.
Nov 08, 2008 | Nokia 1600 Cellular Phone
Jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Jun 14, 2008 | Cell Phones
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SCH-a870 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
