Question about Motorola Mobility HS850 Consumer Headset
Pairing have lost my manual and need the code to pair my device Lost manual for LG Bluetooth HBM-500, any solultions out there?
  • 119 Answers
The code is 0000 when you buy it
i hope you haven't changed it
Posted on Dec 11, 2007
  • 363 Answers
Couldn't find your exact manual.
But hopefully the 550 is similar.
http://www.megaaccy.com/HBM_550.pdf
LG 550 bluetooth headset pairing password lost. pairing not possible without password.
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Dec 22, 2010 | LG HBM-560 Bluetooth Headset
How to reset lg hbm - 550 bluetooth headset,I lost have the pass code? i need your help ...! thanks
If you look in the manual in the link give by jeffsgirl903 it says "When asked for the Pass/PIN code during the pairing procedure,
please enter “0000” (4Zeros)."
Dec 08, 2009 | LG HBM-550 Wireless Headset
I lost instructions on how to pair my lg bluetooth hbm 310 to my cell phone and my phone is asking for a passkey where do I find it on my blur tooth?
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Nov 01, 2009 | LG HBM-310 Bluetooth Headset
Sir I have a LG HBM 730 head set. I cannot pair to my mobile.
Most Pass Codes For These Devices are DEFAULT Codes Such as 1234-- 0000- Try Them.
Jul 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG Bluetooth HBM -500 Passcode for pairing
I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
