Maytag washer leak
Our top loading - 15 year old maytag washing machine has water coming from the bottom of it. All hoses seem to be fine? Trying to figure out cause and an opinion as to whether it is cost effective to fix it or replace it?
  • 164 Answers
The stem kit, boot seal is worn and leaking. if not repaired soon the bearings on the tub and on the brake package will start to rust and sound like a train going by. After 15 years of service its probably time to replace. Call your local service company and get an estimate on replacement of the seals and weigh that against the cost of replacement of machine. hope this helps. please come back and rate my answer.
Posted on Dec 12, 2007
I have a 30 year old top loading washer Maytag 7710. Leaking.
Sometimes the drum gets a hole in it from rust. That can be fixed with a waterproof sealant available at most hardware stores. That is also where you might find a "hose clamp"; if not, you can get one at any auto supply store.
Make sure you get the right size. The best clamps are tightened with a screw driver. Neither of those items are expensive.
One of the two things I suggest should take care of the problem.
Jim Hart
Jun 20, 2010 | Maytag Washing Machines
Leaking drum on maytag washer.
Go to www.repairclinic.com and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
