Question about Sony VPL-CX86 Multimedia Projector
Wireless Connection Keeps Dropping
We have two projectors each no more than about 10 metres away from the nearest WiFi Access points yet these projectors keep "dropping" their connection to the wireless network....any advice?
    Brigadier General:
  • 6,966 Answers
Some generic solutions for WiFi dropping out may include:
1. Use of static IP addresses for the clients (in your case the 2 Sony VPL-CX86s) rather than auto obtain;
2. Disable the WEP/WPA security;
3. Set MAC filter in your router and include MAC addresses of the 2 projectors;
4. Try raising the height/position of the router; and/or
5. use an aftermarket high gain antenna for the router.
As a reminder, WiFi works by line of sight (LOS), anything in between will reduce signal strength/coverage and that include people around/near the projector unknowingly blocking the router.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 12, 2007
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
where is the WPS button? - Canon Community
community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
Cannot connect to wifi hub
Which channel does the WiFi access point use?
Try with a lower number if it's on 12 or 13.
Feb 13, 2015 | Amazon Kindle Fire HD
Have to reset wireless access point several times a day
Make sure it's not getting too hot. That is usually the problem.
Mar 21, 2014 | NetGear R6300 WiFi Router
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
Netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
Keeps dropping out
LOSING WIRELESS CONNECTION
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Jan 20, 2012 | Sonos Computers & Internet
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
Trednet Access Point keeps dropping Network connection
Trednets are know to do this if you have another wireless component close or next to the device. Do you have any 2.4ghz phones? Cell phones? Other wireless devices? If you have not tried yet, Try switching the channel on the access point. If its not a channel issue, try getting new firmware and test the signal strenth with a wireless sniffer such as Net Stumbler
Jun 14, 2007 | Trendware TEW-450APB (TEW450APB) 802.11b/g...
Sony VPL-CX86 Multimedia Projector Logo
136 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
