Question about HP OfficeJet 7110 All-In-One Thermal Printer
Scanner failure error keeping always
I have 5 printers in my company allof working well but daily printers are keeping one message in display.this is scanner failure.
in this moment what should i do plz hellp me as soon as possible
  • rondel39 Dec 21, 2007
    My printer works fine but I have to turn on and off constantly I keep getting the error message, "scanner error turn power off and back on." I am told by HP that it is doing that due to the bulb since it works off of heat but they say bulb cannot be replaced..Does anyone have idea or how to get and replace the bulb?
  • aj1900 Dec 26, 2007
    I have the same problem! It started after I scanned a document a year ago and the scanner error keeps appearing!! Even after I shut down and start the printer the error message appears! Please Help!!
I have the same issue and HP says it is the bulbs so does others on this website. Presently I have 2 bulbs ordered from California at $22.00 each. I have already had the printer apart and the bulbs CAN BE replaced. Very simple to get apart to get to the bulbs. I am betting the bulbs will fix it.
rondel39
Posted on Jan 07, 2008
HOLD # & 9 WHILE PLUGGING IN PRINTER TO DO FULL RESET
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer still prints, but make noise when the scanner lamp warms up. After that, the screen says, "Scanner Error 5". What's the problem?
Hi tatnle,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the enter and the * button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jul 15, 2010 | HP LaserJet 2840 All-In-One Printer
HP m2727nf scanner error 5
Hi Anataloi,
2. Hold down the right arrow and the cancel button
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
I have Networked hp model M2727nf all-in-one printer/scanner/fax.displies error "scanner error 5" on the display screen. i turned off/on the machine more than 4 or 5 times the error does not go away!
This is due to a formatter failure.
Try an nvram
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Jun 15, 2010 | HP LaserJet 2840 All-In-One Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Our hp lj doesn't work anymore. After restart it says "Scan Error 5" or "Scan error8". This morning I managed to send a last fax but after this it stopped working. We had problems with printing those last...
this printer is experiencing what is known as a formatter/scanner assembly failure, hp has a service note issued to service printer up to 2 years after the purchase date.
if this does not work contact hp. 1800-334-5144 in order for them to create a case under the service note and have the printer serviced. Both the scanner assembly and formatter board need to be replaced.
Al
Mar 24, 2010 | HP Laserjet M2727nf Multifunction Printer
Scanner error 5
Hi Myang,
Al
Nov 11, 2009 | HP LaserJet M1522nf Multifunction Printer...
Cartride error 50c on display
Hi there Error 50c
ok ok try see if this works
color cartridge.
Oct 31, 2009 | Dell A960 All-In-One InkJet Printer
My M2727nf doesn't coppy or scan. message displays " error 5 Turn off and turn on." After turning off and on, it keeps displaying the same message.
Hi this is def a hardware failure:
Try doing a nvram
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
Al
Oct 10, 2009 | HP Laserjet M2727nf Multifunction Printer
R40 Scanner Failure
Hello I have a little problem my printer print well for scanning it is not tell me what I have to do and the copy too doesn't work properly.
thank you for your help. May God bless you in everything that you udertake in life. keep on
Apr 16, 2008 | HP OfficeJet r40 InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
