Question about Mitsubishi WS-55809 55" Rear Projection Television
No Luck I got in and tried but it didn't make any difference. Any other Ideas ?
  • Racerxedge Dec 11, 2007
    When I 1st turn the TV on Sometimes it takes a Minute to get a signal, Then Sometimes it says on and other times it will loose the signal and then come on again.
    Sorry i didn't Realize i started a New Post.
    Pretty much the same thing. I have mine connected straight to the cable wire coming in the house.
    Turning it on and off does Not seem to help but when i get a signal and i leave it on for a while, everything is warmed up it comes on right away, even if i turn it off then on again.
    President:
  • 4,402 Answers
Whats happening you started a new post.
Posted on Dec 11, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 11, 2007
    is this the same as what your getting?
    when connecting I
    do not get a picture most of the time. I have selected ANT-A and ANT-B
    with the same resuts. Sometimes I will get a signal and most of the
    times not. Turning TV on/off/on has fixed it, going into the menu and
    editing anything can sometimes fix it. Most of the time I get no
    picture/soundm from Disc satellite box.
    Here is what I know so far:
    -There are no codes
    -The green light is always on when I turn it on.
    -I can always get to any of the menu screens.
    -I can navigate all of these menu screens without any problems.
    -All front panel buttons work and the remote works.
    -A known good LCD TV was brought in and I always get good reception from
    this same sat box, cables, etc.
    -Maybe 10% of the time, either turning the TV or going to any menu screen
    will get me a picture. Sometimes letting the TV remain ON will get a
    picture -in about 3-5 minutes (happened twice??)
    -No difference with ANT-A or ANT-B or channel 3 or 4.
    -DVD input is NG into ANT-A or ANT-B.
  • Cary Farah
    best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
  • Cary Farah
    Sounds like the tuner.
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
#1 and #4 are not firing I changed the coil pack and still no change any ideas
You said you changed the coil pack and the wires but didn't mention the plugs. Try moving one of the plugs to a different cylinder and see if the miss follows it. It could also be the ignition module. (the thing the coil packs mount to.)
Oct 05, 2012 | 1993 Chevrolet Lumina
My CD players says check magazine when magazine is already in there.....
My 1999 Beetle did the same thing. I didn't have any luck repairing it, even tried a different magazine but nothing helped. Fortunately I found someone local selling a used trunk-mounted CD changer for $10, so I bought that and it worked like a champ.
So for me, I ended up having to replace the CD changer to fix this problem. Hope you have better luck.
Aug 16, 2012 | 1999 Volkswagen Beetle
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Jun 30, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hilti service light on tried bushes and taking off handle to reset light but still on after putting back together
I've had he same problem with Hilti's. If replacing the brushes didn't take care of the problem you have to send it to them so they can diagnose the problem and reset the handle. You can try calling their service number but they wouldn't tell me how to reset the handle where the fault sensor is, maybe you'll have different luck.
Feb 03, 2012 | Drills
How to get Google back to English ?
Clear your internet cache and then try switching to English
Dec 30, 2011 | Dell Computers & Internet
2006 hyundai santa fe wont start
check your battery first, if not replace your starter.
Dec 28, 2011 | 2002 Hyundai Santa Fe
My 1980 sportster back fires when started but after its running its OK.This just started what could cause this. Thanks JL
By the term "backfire",are you referring to the engine spitting back through the carburetor or popping through the exhaust system? You also didn't tell me what type of carburetor the bike is equipped with. A lot of the owners of early Sportsters didn't like the original carbs and replaced them with aftermarket carbs. Since the carburetors use different starting circuit designs, it makes a difference in how the engine is started. It really makes no difference and I've heard many bikes that do either or both of these things when starting. What does make a difference is how easily it startes and how it runs AFTER it starts. If it's simply a spit or a pop, this is not unusual. Does the bike run the way it's supposed to? If not, that's what we need to look at.
Good Luck
Steve
Sep 09, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Every time I start my computer it says master boot record error and press a key. After I do it says disk boot failure, insert system disk and press enter. I don't have system disk because my computer...
You can see if there is a recovery partition on you hard drive by pressing the F12 key as soon as you turn on your PC and select boot partition, if not, you will need to buy a set of recovery disks from the manufacturer, it will cost you around $30. If you have a Windows CD you can boot with it and install Windows and download all the device drivers from the manufacturer site. I hope this helps. Good luck and have a fantastic day.
Jun 16, 2011 | Computers & Internet
Mitsubishi WS-55809 55" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
