HP PSC 1210 All-In-One InkJet Printer
Problem for HP PSC 1210 All-In-One InkJet Printer
Scanning function
By PineRidge on Dec 11, 2007
I have had a 1210 for several years on both ME and XP platforms.Characteristically, the scanning function either stops working or gets 'lost'. My usual fix has been to remove both power and USB connection from the unit to let it refresh. This has worked well in the past. Lately though, when Windows reinstalls the device, there is no scanning function. I have tried to remove the driver and reinstall from original disc, but I get a message from Windows that more up-to-date software is available. Windows
XP will not let me reinstall from the original disc. The unit is admittedly 'old' and probably should be replaced, but this problem has been bugging me for some months now.
Any sugestions?
Comments:
Dec 27, 2007
- Been There. Done that. When I load the installation disc a message appears which ionforms me that a newer version of the software in on my machine. It will not let me install from the disc. I have tried using HP's removal software, but it doesn't sufficiently clean the old stuff to let me load from scratch. Thanks anyway.
P
Solution #1
posted on Dec 27, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
well i had the same problem but i suggst to do as the following to see if your problem could be solved you can try to restart the the 1210 or you didnt connect the usb cable rigth cause after you connect the usb cable you need to put in the deskjet disk that came with the 1210 and follow the directions from the wizard.
Popular Solutions for HP PSC 1210 All-In-One InkJet
Questions and Unsolved Problems for HP PSC 1210 All-In-One InkJet
Do you recommend HP PSC 1210 All-In-One InkJet Printer?
Answer
Answer
cartridge no. of 1210 printer and it price in combo pack and single black and color
Answer
always printer yhe same page that I have print a month agai can not print anyting else?
Answer
moved house printer turns on but wont work, light on bur cant turn off or anything?
Answer
Printer is plugges in correctly - but all the lights are flashing..
Answer
theres a flashing light next to the "check print cartridge" and i dont know whats wrong
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
