Question about Dewalt DW746X 10" woodworker's table saw with rai
Husqvana saw Purchased a Husq without bar or blade, boought both an put on saw, blade turned but as i tightned the cover nut the blade did not move ,whats wrong
  • 25 Answers
Looks like you need a better explanation of what's going on here.
Posted on Apr 24, 2008
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
Chain came off, how do put it back?
Remove the cover. Loosen the two bolts that hold the chainsaw bar. Slide the bar back (it has a long slot for adjustment) until the blade can be lifted out of the track and sprocket. To replace the blade slip it onto the sprocket and the bar. You must hold the bar level while replacing the blade. Be sure the blade fits into the track around the bar. Once in place double check the placement on the sprocket and pull the bar outward until all the slack is removed from the chain blade. Holding firmly, (it would help to have someone assisting) keep the pressure on the blade and bar while replacing the bolt nuts. Then replace the hood cover. Smile.
Sep 27, 2014 | Worx Jaw Saw Replacement Saw Chain
How to replace chainsaw chain
The bar is usually clamped with two hex nuts, you usually need to remove them, this allows the chain cover to come away, then wind back the tension adjusting screw ( with a flat blade screwdriver on a Husqvana other brands may be different ) back until the chain is loose enough to come off, the bar will also come off at this point.
It is a good opportunity to give everything a good clean at this stage and make sure the oil ways to the bar are clean and not blocked with wood dust, check the nose wheel on the bar spins freely and maybe grease it.
Put the new chain over the drive pulley the same way as the old chain came off, line it up in the bar slot and if you have the tension adjust wound back far enough for a new chain the bar will just flop over the two clamp bolts, replace the cover, and just do the nuts up finger tight so the tension adjust can be wound up to take the slack out of the chain.... not too tight ! it should still spin by hand without too much friction and you should be able to lift a link up half way out of the slot in the middle of the bar with your fingers.
Check the oil is getting to the chain by running at full speed with the end of the bar held just above a flat piece of clean wood, it should throw off a faint line of oil from the chain onto the wood.
Keep your chain sharp...
Happy sawing !
Nov 26, 2013 | Garden
Manual ryobi chainsaw
Chain replacement is basically the same on all chainsaws. Loosen the side retaining nuts on the cover over the chain. Now loosen the chain tension screw ( usually a flat headed screw) at least 4 full turns. Put the saw on its side with the blade up. Remove those side cover nuts and the side cover - the blade should sag as you remove the nuts. push the blade towards the engine, paying attention to the direction of the teeth on the chain. remove the chain and clean out the junk from behind the chain around the sprocket and from the inside of the side cover. The emergency brake band is located inside the cover - make sure you clean out the debris from around the band, tensioner screw assembly, and cover. Re-install the new chain, orienting the teeth in the correct direction. Re-install the side cover, making sure the tensioner pin goes into the hole in the bar ( blade). Slightly tighten the side nuts, then re-tension the chain until you can just pull the teeth off the bar. tighten the nuts, being sure you don't over tighten them ( a little past snug is good). Run the saw for a few minutes ( doing 1 cut will speed this step along). Loosen the side cover nuts and re-tension the chain, the re-tighten the nuts.
Hope this helps!!
Chain wont tighten up
Jeff:
Loosen the two nuts on the right side cover of the saw (1/2 inch socket) turn them out 2 turns. Use a flat blade screwdriver on the screw at the right side front of the housing (near where the bar comes out of the saw). Turn the screw right until the chain can only be pulled up 1/8 of an inch at the top center of the bar. tighten the two 1/2 inch nuts. The two nuts clamp the bar so it won't move. If the chain tensioner still won't work, remove the right side housing by removing the two 1/2 inch nuts and look at the tensioner assembly and how it fits into the chain bar. The problem will be obvious. If you need to replace the tensioner assembly, a new one can be ordered through http://www.husqvarna.com.
Aug 16, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
May 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Does the husq 440e have an oil adjustment on it?
Hi mwaltz48,
Yes, Huskys have a screw adjustment on the bottom, under the chain sprocket assembly.
While looking at the bar side of the saw, turn it over and you'll see a screw that has 3 positions.
Turn the screw to the right will decrease the oil flow, left to increase it. If you put a longer blade on, you should increase the oil flow.
A way to check your oil flow is to run the saw with the blade pointing at something light, such as a freshly cut chunk of wood, or the end of a log, etc. You should see a light line of oil appear.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Do you have an instruction I can download? I need to know how to load a new blade. Thanks.
What you ask is nearly impossible without knowing for sure what kind of chainsaw you want help with. That being said, most chainsaws have a bar that the chain runs on. They are not called blades on a typical saw. To replace the chain or the bar you have to loosen the two nuts that clamp the bar tight. It helps if you loosen the adjustment screw on the front as well. The clamp is also the side cover for the clutch area. So the two nuts that hold the bar tight also hold the right side cover of the saw. To get the chain off you have to remove that cover even if you don't completely remove the bar.
Aug 20, 2010 | Garden
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
Dewalt DW746X 10" woodworker's table saw with rai Logo
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
