Question about LaCie d2 DVD-RW Burner
DVD RW reading problem
After burning onto  a Tevion DVD+RW disc, I was able to read the data okay. The next day the disc could not be recognised in any way. I'm using Toast 7 and when entering 'disc info' I get the caption: 'There is no disc in the recorder'. The disc does not exist to my powerbook drive either. I have probably burned to this disc before and erased successfully. I also have 4 other discs of this type and none of these will work either now, whereas they all did before. What can I do to resolve this please in simple terms!?
  • Peter Mac Sep 28, 2008
    Tevion DVD Recorder TDR930 shows "no disc" on all inserted discs including DVD +_ RW and commercial DVD's from store.
  • Ven0m Jan 28, 2009
    I have the same problem you have with the discs, but as far as i know my dvd drive works fine, it works in writing and reading other discs, i think it may just be the Tevion RW discs.
  • 2,427 Answers
Ok it seems as if the drive may be dying or is dead. You said you used these disc before so the problem is with the media(disc) its with the medium*the drive) I dont think flashing the firware in this case will hely you will need to replace the drive :)
Posted on Dec 30, 2007
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
DMR-EZ48V does not recognise Sony DVD+RW disks
Hello
If there are some writing errors in data, or sctraches, Sony sets won't read the disc well; especially to DVD+RW discs. OK.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
My DVD RW does not recognise the disc as being loaded
You need to buy software to burn DVD's A dvd drive will not burn DVD's on it's own.
Nov 11, 2008 | Maxell - DVD-R - 1 x 120min (567613) Media
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
Wont burn data dvd
dear
i have this kind of drive ( 7W036-A01) , IT READ AND WRITE CD BUT IT COULDNT WRITE DVD ( EVEN IT READ DVD IN GOOD WAY )
PLEASE CAN ANY ONE HELP ?????
Jul 31, 2007 | Dell (7W036) DVD+RW Burner
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
LaCie d2 DVD-RW Burner Logo
178 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
