Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Yellow flame One of the five burners (right rear) has a yellow flame the leaves the pots black when used. The other burners are fine. This range was installed in a new home and is being used on LP gas. Installation was done by the plumbing contractor. Range is only 3 months old.
  • 640 Answers
Lp burners dirty.clean out the orfice and burner and this should solve your problem.
Posted on Dec 11, 2007
Flame on main hob of range master 110 is yellow and smelly also black sooty deposit left on jets
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
Apr 25, 2016 | Rangemaster 110 (Gas) Kitchen Range
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
The spuds need adjustment on the top burner gas valves. The oven safety valve needs adjustment too. Get a good fitting wrench and tighten down the spuds till the yellow goes away. Adjust the air shutters as needed.
Here is a nice video:
Natural/Propane conversion Video
Dec 22, 2009 | Tappan MGF500PBW Gas Kitchen Range
Poor burner flame
You have to adjust the air flow shutter on the burner tubes.
Jul 04, 2009 | Tappan MGF500PBW Gas Kitchen Range
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
217 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
