My kenmore won't pump out the water. what could be wrong? At the beginning of the cycle, while the water is coming in, the agitator begins.
Couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
