Question about Brother MFC 210C All-In-One InkJet Printer
Brother fax mfc 215
It is dead
  • Anonymous Mar 04, 2008
    This is the 3rd time it is dead, it looks as if there was a power miss contact. Usually I try to unplug and then plug it back, but this time I get nothing. I remains dead,
  • 832 Answers
..and will not come back alive...
if you had tested it by unplug from power and replug to power without any sign of live!
This is because one part within the main circuit board is defective. It has to be replaced which more costly than a new mfc 240c!
Posted on Dec 13, 2007
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
My Brogher MFC-7840W is not printing any fax or sending any fax. When someone sends me a fax, it rings and then it goes dead. When I try to send a fax, it scans the document but then goes dead. I don't...
normally the only thing that could block you from sending a fax would be the connection to the phone line. make sure the phone wire is plugged into the line jack (not ext) and going straight to the wal, no splitters or extensions. if it still cannot send after this try another wire or jack
Mar 24, 2010 | Brother MFC 7840W Printer
My fax BROTHER MFC-215C does not print after RECEIVING. it also does not send fax after scanning.
The solution, finally, was very simple: To disconnect the mains voltage, for several days, from BROTHER MFC-215 .
After that, I was successful to receive and print the incoming faxes.
Thank you very much for your willing to help.
jacobr05
Mar 27, 2009 | Brother Multi-Function Center® MFC-215C...
How do I stop the brother MFC-215 fax from printing out fax reports?
To turn off transmit reports:
Press Menu/Set
Press 2
Press 4
Press 1
Choose "off" by pressing the up or down arrow keys
Press Menu / Set
Press Stop/Exit
To turn off the Journal time periods (the default is set for every 50 faxes):
Press Menu/Set
Press 2
Press 4
Press 2
Press Menu/Set
Press Stop/Exit
Apr 09, 2008 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
