Home | Dacor | Epicure ERD36 Dual Fuel (Electric and Gas... | I too have the F1 err...
Dacor Epicure ERD36 Dual Fuel  Kitchen Range
Problem for Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen...
I too have the F1 error code and alarm sounding randomly.
By irene_wojtys on Sep 13, 2009
I have a similar problem with thr F1 warning alarm that goes off at all hours of the day and night. The oven and range top work, but the alarm is driving us nuts. This happened last year and the technician could not fix the problem unless the alarm was actively beeping. Apparently the F1 code means it could be one of two things. Last year I had the circuit board replaced for around $400 and a year later the same problem! I now keep the circuit breaker off until I need to use the oven/stove and then turn the circuit breaker back on. The alarm is most annoying and when I contacted the manufacturer I was told there is no way to shut off this error alarm. Eventually, the alarm will keep going continually and I will contact the technician to replace the part. However, I do have to say that I hear a clicking sound - like the stove is trying to light - when the circuit breaker switch is turning back on.
Popular Solutions for Dacor Epicure ERD36 Dual Fuel
Questions and Unsolved Problems for Dacor Epicure ERD36 Dual Fuel
Do you recommend Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range?
Answer
Answer
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when... (More)
Answer
We have had a problem with the control panel since we bought this unit. Dacor rep says to turn stove... (More)
Answer
Can you suggest a solution ? The guide indicates F1 means ""Element relay circuit...
Answer
This is a caravan oven and has been out of action for this summer period any help is gratefully... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dacor Epicure ERD36 Dual Fuel ...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
