Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped working
About 2 months ago, you suggested I replace the monitor switch on my microwave because the unit came on when I opened the door. This fixed the problem and it has been running great since then. Just yesterday, everything stopped working, as if I unplugged the unit. I checked the house CB and the outlet for power...both OK. Is there an internal fuse that might be giving me a problem?
  • DITY Pete Dec 16, 2007
    I replaced the ceramic fuse with an exact type (20A 250V). When I truned the microwave on, on my bench, the fuse blew again as soon as the microwave kicked in and began to draw heavy power. I tried a second fuse thinking it might have been a bad fuse, but I had the same results. Any ideas?
  • inman486 Jul 07, 2008
    I followed all the common steps. Power, power to circuit. Took the unit out and found the fuse. 15 amp tested and showed bad. Replaced with new one, turned on unit. Clock came and display panel. When I shut the door and turned on microwave to cook, blew the fuss after 5 seconds of run time. Made a real loud humming noise. Replaced that fuss and tried again and got the exact same results.
    Problem Solver:
  • 4 Answers
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Posted on Dec 11, 2007
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Keeps running
interlock switches.. more than likely it is the monitor switch in the middle that needs to be replaced
Mar 17, 2009 | Microwave Ovens
FUSE on Microwave still blows
Sounds like a power supply problem. There is a capacitor in the unit which often gives problems. This may be beyond non-professional help and may have been started when you had the other failure.
Dec 20, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1339BW002 Microwave stopped working
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1339BW002 Stopped working
Dec 11, 2007 | Microwave Ovens
It blows the fuse each time open the door if this em-Z2100GS
Probably a bad door switch or door switch mount. It may have gotten damaged or misaligned in shipping.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
Being only 2 months old, I would think you have a warranty, but maybe not. I'd contact the seller to see.
Nov 21, 2007 | Sanyo EM-Z2100GS Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
