Question about Samsung Syncmaster 17" 720N Monitor
Magic Bright Hi, My Magic Button appears to be stuck. It keeps coming up on the screen and switching between the four brightnesses. We have tried pushing the button on the moniter to shut it off, we shut off and unplugged the moniter. It is really annoying and I need HELP!!!
  • 1 more comment
  • sinedol Dec 14, 2007
    i got the same problem the magic brite just runs up and down,and all the control buttons on the monitor are blocked,sometimes it start to pop up the menu and it wont stop on off all the time please help jebem ti bogaaaaaaaaaaaa
  • rharj2000 Apr 25, 2008
    The Brightness indicator is displayed in the middle of the screen and I cannot figure out hoe to suppress it.
  • vanryt Oct 20, 2008
    I have the same piece of ****, it was a warranty replacement ! It's now
    out of warranty ans Samsung wil do nothing. Next itme i'll buy a
    cheaper make..
    Problem Solver:
  • 19 Answers
Problem is made by switches which are bad quality, you have to take your monitor to the nearest samsung service center or if you want you can change this switches by yourself. You can find them in conrad stores named phap3363 and art.nr: 700310 - 62
Posted on Jan 17, 2008
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
The Bright/Contrast window, controlled from the monitor itself, keeps popping up. The select pane continues to switch between the Bright selection and the Contrast selection. When it finally stops...
Sounds like your monitor is going bad. You might get some more use out of it if you power it off for a couple hours and try again but my guess is this is a heat-related failure that is common on ViewSonic monitors.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | ViewSonic Vx2250wmled LCD Monitor
My printer is stuck in a "preparing printer" loop and wont get out of it even after i switch on and off or unplug it!
Hello
Same problem for me. found a procedure to get back to Service Menu which works for HP 8600 :
https://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/X476dw-doesn-t-boot-Help/td-p/5044674
1. Unplug the power cord (!)
2. Insert power plug while keeping power button pressed.
3. While the HP logo appears on the screen, keep the button pressed. The screen will go dark. KEEP THE BUTTON PRESSED for another 5-10 seconds.
4. Let go of the button. The screen remains black.
5. Push Home-Back-Home-Home button. The buttons are usually not visible, so refer to the manual, where they are on the touch screen. (Home is left of the upper left corner of the touchscreen, Back is left of the lower left corner)
6. A blue menu comes up, with four choices.
7. MENU on the lower right has a FULL RESET option.
Apr 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Four Way Flashers
your flasher button is stuck for your hazzards you need a new switch
but to turn off flashers you will have to push the button till it goes off the button is stuck gotta keep pushing it till it relieves the point switch
Jun 01, 2008 | 1998 Plymouth Neon
Samsung syncmaster 720 n
Is the auto adjust button stuck?
May 09, 2008 | Samsung SyncMaster 720N Monitor
Brightness pops up
it may just be stuck , if you push the button does it click like the others, a little wd40 around the button , lightly, may unstick it.
or you have to take the bezel off and see if the positioning is the issue.
Apr 25, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Turning on
I second quavuama. I had the same symptoms after my four-year-old "broke" it. He actually figured it out and suggested the fix. He said "Daddy, the little button is stuck..." OK, yeah right, I said. But he pointed to the small auto shut-off button just above the source and setup buttons. When the lid closes the button is pushed down and off goes the picture. Well little four-year-old fingers was fingering the button and it got stuck in the down position. I used a sharp tip to work it back to the "sprung" position. Picture now comes on.
Mar 13, 2008 | Insignia NS-PDVD8 Portable DVD Player
Compaq 7540 brightness
Your button is stuck. If it is stuck on the external button, try plying it forward with a needle, if it is broken internally, a technician can fix the switch on the board for you.
Nov 26, 2007 | Compaq CV 7500 17" CRT Monitor
Samsung Syncmaster 17" 720N Monitor Logo
700 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
