Question about Microsoft Windows Vista Ultimate Edition
Software compatibility I was working on TURBO C&C++ on XP but Vista 's resolution or its properties or some hing is not allowing me to work on it in full swing ... 1. I Cant run graphics programs... 2. I cant maximise the window using Alt-Enter as iused to do in XP.
  • sanmany Dec 11, 2007
    3. I cant Run the programs with header Graphics.h
A/A
i have buy a new lenovo laptop with vista home premium,but whenever i install turbo c on vista it generatesa error that it dos not support full screem mode.plz write me a solution.
touseef07lone@yahoo.co.in
Posted on Dec 12, 2007
  • 23 Answers
Hi san, many of vista's problems can be resloved by useing there combatilty mode, its in the properties if you right click on the programe. Make sure to click "Run this program in XP SP2" and "run as administaror" are checked. Good Luck
CoDoc
Posted on Dec 11, 2007
IS THERE A PROGRAM TO ALLOW STAR TREK PINBALL TO OPERATE ON WINDOWS VISTA?
WIndows Vista allows you to run it in compatibility mode for previous Windows versions such windows XP. I suggest you try it and see if it works. To do this, Right-Click on Pinball.exe and click properties
In the properties window there is an option called compatibility. CLick on that tab. Once you click that you will see an option called run this program in compatibility mode for... Click the checkbox next to that and choose Windows XP service Pack 2 from the list
That should most likely do the trick. Give it a shot and let me know so that we can try something else. PS: Bad rating = No Further help!
Sep 16, 2011 | Interplay Productions Star Trek: Pinball...
Tip
Software compatibility issues with Windows Vista
ISSUE- Software compatibility issues with Windows Vista
SYMPTOMS-
Fortunately, many applications still work fine under Windows Vista. However, there are some applications which are incompatible with Windows Vista because they are not able to handle the changes in Windows Vista compared to Windows XP. User Account Control is one of those changes to offer a better secured operating system. Sometimes, this problem is solved by (temporarily) disabling User Account Control (which can be done at the item User Accounts in the Control Panel). But for security reasons, deactivating UAC is not advised!
RESOLUTION/ WORKAROUND-
Run as administrator:
Does an application not function properly or does it show an error message every time it is used, try to run it with additional administrator rights! Because most compatibility issues are solved by running an application with additional administrator rights. By default, an application is not started with those additional rights, but this can be done manually by right clicking (the shortcut to) the application and to choose for Run as administrator. Those administrator rights can also be added by default by right clicking the shortcut to the application and to select Properties, tab Shortcut, button Advanced and to activate the option Run as administrator.
Limited permissions:
The issues concerning the limited permissions is related to the problem with the administrator rights. Without the permission to modify files in a certain location, an application is not able to save a file in this folder (as example, it is not possible to change or add files in the C:\Program Files without the permissions to do it). In most cases this problem can be solved by running an application with additional administrator rights. A better alternative is adding permissions to modify the concerning folder. This is done by right clicking the folder and to chose for Properties, tab Security, button Edit (or the button Advanced) and to activate the option Full control for the concerning user account.
Virtual Store: virtualization of files
In Windows Vista, many folders are secured, which makes it impossible for an application to make changes to the files in the folders. For example, the folder C:\Program Files is secured: only an application with additional administrator rights is able to modify the files! However, many older applications continuously try to store files in this folder, which should not be placed there. To solve this issue, Windows Vista uses virtualization of files (which are stored in the Virtual Store). The application is not aware of this virtualization, and thinks the files are stored on the prescribed location. Virtualization is done separately for every user account, the files are stored in C:\Users\loginname\AppData\Local\VirtualStore. Program Files is one of the folders in the Virtual Store, which contains the user specific settings for the applications. All users must change the settings of the virtualized applications separately. This is an advantage as well because the changes won't effect the other users.
DISABLING THE VIRTUALIZATION
Because of the virtualization, files are stored on multiple locations (every user account has it's own virtualization folder), which makes it hard to handle them (the incoming folder of the file sharing software eMule is a good example). If the virtualization is unwanted because the files (and settings) have to be applied to all user accounts? This can be realized by giving all user accounts permissions to fully control all the files in the folder which else will be virtualized. Right click the folder and chose for Properties, tab Security, select Users and set the permissions to Full Control. If this procedure is to much work, the application can be run as administrator as well. This is done automatically by right clicking the shortcut and to chose for Properties, tab Shortcut, button Advanced.
Compatibility issues with older software:
Windows Vista manages some things differently compared to previous Windows editions, which can result in compatibility issues for older software. Some of the compatibility issues are solved by running a program in the Windows XP compatibility mode. This is done with the tab Compatibility of the program shortcut Properties (available by right clicking the shortcut). The compatibility mode pretends the program it is running in an earlier Windows edition. Unfortunately, it is not always a solution to compatibility problems.
TIP: If an older program is still not functioning as it should be, a virtual environment of a previous Windows edition can be a definitive solution to the problem. Here fore, Microsoft's has created the tool Virtual PC (download: www.microsoft.com/windows/virtualpc). This software virtualizes a whole new computer on which a previous Windows version can be installed.
Which applications are compatible?
Although there are compatibility issues, there are many programs which work properly (with or without additional permissions) within Windows Vista. Microsoft investigated many programs and made a list of Windows Vista-compatible software which is devided in two categories: the software is certified for Vista or the software works with Vista. When the software is tested by Microsoft and placed in one of those categories, the vendor is allowed to label the software with the logo Certified for Windows Vista or Works with Windows Vista. The page www.iexbeta.com gives a useful summation of (almost) Windows Vista compatible software. The combination of these sources must be sufficient to tell whether a program will work properly within Windows Vista.
on May 10, 2010 | Computers & Internet
Type to Learn 3
You have a couple of choices. You can upgrade to version 4. It runs under Vista (and may be Win 7 compatible - worst case run with the compatibility mode enabled when you install (right click on the installer and see properties (Compatibility Tab, Run as Vista), then right click and run as administrator) Then repeat the compatibility command for the actual program).
Try the current program in the Compatibility mode (this is iffy for an XP and older code). Alternatively install a virtual computer with XP on the computer. Win7 Pro and Ultimate allow you to run XP mode for a free XP virtual computer. All other virtual computer programs require a paid license for XP to work. Then install and run the program in the virtual computer.
I hope this helps.
Jun 04, 2010 | Sunburst Type to Learn Jr. (t04213)
Had a power outage when it came back on the monitor font and resoultion if huge I tried to change the pixels but couldn't
you can change the resolution from the display properties of your computer.
if you're using windows xp:
right-click on desktop > properties > settings. then try to change the resolution.
if you're using windows vista/7
right-click on desktop > screen resolution then change the settings.
**if nothing happens.
check the software of your graphics/video card (nvidia etc.) i believe there is an option there where-in you can change the resolution of you computer. check if it works.
** if nothing happens
check if the driver software is installed.
for windows xp:
right-click on my computer > properties > hardware then click on device manager.
for windows vista/7:
right-click on computer > properties > device manager (left side of the window.)
when you're at device manager window, check if there's any question marks. if there is. re-install the driver and see if it works.
let me know if it solved the problem.
Feb 23, 2010 | Computers & Internet
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
Oct 12, 2009 | Microsoft Windows Vista Ultimate Edition
Can't click Accept in Software License Agreement dialog box in Ad
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
May 17, 2009 | Adobe Acrobat 7.0 Professional
3dhome arch designe delujx 8 i have this software and when i use it and from the menue i s\choose appearance it is getting stopped and appears window saying software p\not working ok this happen only on...
Because it is an old version--> therefore it is not reasy for W Vista--> Try to use this sw in Compatibility mode--> Desktop--> right click on the program icon--> Properties--> compatibility--> select Windows XP
Patricia
Sep 20, 2008 | Broderbund 3D Home Architect Deluxe 6...
Turbo c/c++ not working in full screen mode
The problem the dos is not compatible with windows xp.Right the launcher file and select properties->screen->select window(i.e deselect full screen) now the program will launch hopefully,it worked for me. now go to full screen by pressing alt+enter.
Aug 20, 2008 | Dell Inspiron 1501 Notebook
Install Vista on Dell optiplex gx 260
The big problem you will ever face with Windows Vista using optiplex gx260 is the screen resolution...This is a great hurdle in the upgradation of Windows...You're also to keep in mind that there are some softwares which are not compatable with Vista like folder lock etc...So I'd suggest not to shift to Vista...XP is still the best option...allowing multiple tasks to perform securely, faster and without any compatability issue...Enjoy using Windows XP...
May 08, 2008 | Computers & Internet
Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Regards
Chris 2030
Jan 12, 2008 | Sony CLIE PEG-T615C Handheld
Microsoft Windows Vista Ultimate Edition Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
