Question about Radio Communications
Led on a uniden grant xL
The led does not work, I changed it out and still doesn't work. What could be wrong?
    Brigadier General:
  • 6,966 Answers
All LEDs are polarity sensitive since they are unidirectional (anode & cathode). If the LED was connected the other way around, then even with a known good new LED, it won't light up. At other times, it is possible that the LED has a limiting resistor and/or another diode in series with its supply line. You need to check if this is also open.
Good luck and kind regards.
Posted on Dec 12, 2007
How to wire a 4 pin ProComm microphone to work on a 5 pin microphone for a Uniden Grant XL
The simplest way is to order a microphone adapter from ebay or a reputable CB shop. I have all my mics wired for standard 4 pin cobra. The standard 4 pin cobra is the most common and if you keep adapters handy then you can use all different kinds of mics on different radios.
Apr 09, 2016 | Uniden Radio Communications
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
Does anyone know how to wire a turner + 2 to a uniden grant?
that combination isn't possible without changing the cord and doing a major rewire of the mic
Apr 24, 2014 | Uniden PC78ELITE 40-Channels Base CB Radio
How to adjust frequency on a uniden Grant XL
Take this to a shop that does it for a living, they have the correct equipment needed to align this rig
Mar 08, 2014 | Uniden GRANTLT 40-Channels Base CB Radio
Cobra 148 gtlcobra 148 gtl DX
Nice choice of radio i have the Grant LX Uniden which is roughly the older version.
This site may be of interest also if you choose the channel mod make sure you have the right PLL.
Nov 16, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden president grant stops transmitting wait 1 or2 minutes and it will transmit for a little bit then does it again never lose my recieve thank you for your intrest
i cant afford 20 dollars to fix that radio your add said free i am laid off the old grant will have to waite i am not a teck have no idea what is wrong thank you for your time sorry to bother you ihave a good ole cobra29 that i talk on now grandadmac50@ yahoo.comm
Jan 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden Grant XL No Transmit
on the back of the radio you will see a small circuit board with a transistor on it this is your am regulator.check to see if that has gone bad
Jan 27, 2009 | Radio Communications
Need manuel
I am assuming this is a CB radio, and i've found a manual for the LT model, found below, but not the XL. It takes you to Uniden's website. You may have to contact them directly if this doesn't help you out. If you haven't already, check the label on back for the model #. It may be listed that way, as there are some XL models listed.
Good luck, and please remember to rate my advice.
Feb 28, 2008 | Audio Players & Recorders
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
