Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Refer Icemake not working
I have a Kitchenaid refer Model KSRL25FRST04. I purchased this refer from Lowe's for what I thought was a good price because it needed a control board that came with it. I installed the new board and everything worked well except the icmaker that does nothing. I have water because the chilled water works on the door. If I open the freezer door and hold the switches closed and there is a flashing light for the ice level eye. It flashes and never goes solid, I'm not sure if it should? Can you help me?
  • Anonymous Apr 06, 2008
    I have a problem with a Kitchenaid icecaker. Chilled water dispenses.No Ice. Icemaker tray does not fill with water. Chilled water tap works fine. I changed the water inlet valve at the bottom rear on advise of Sears repairman. Still no water in the ice tray. It cycles but water does not run. Anybody got any ideas???
The light is supposed to flash twice with a 1 second intermission. When the fridge door is closed the light stays ON. Check this by pushing the white flap to the right of the icemaker while the door is open
Posted on Dec 11, 2007
  • franwallar Mar 16, 2011
    i have a kitchen aid fridge that jambes all the time. this fridge is 1 1/2 years old. paid a lot for it because of special size being built in. it was replaced at about 3 months old but the problem continues with the new one.
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Is there a ice maker avaiable for a GE TBX211A The Refrigerator was Made 10/19/98
Yes their is a icemake r kit that will fit in your ref.
its part number IM6 and contains the icemaker,ice storage bucket,water inlet valve and all the necessary tubing and wiring for it...what is not included would be a water supply line that connects from the house plumbing to the icemaker
Its available from Lowe's,HomeDepot, or online many places (google IM6)
Sep 08, 2011 | GE (GTS16BCS) Top Freezer Refrigerator
KSM75 Mixer: I want a an additional bowl..what miodel do I need...
For Accessories for the KitchenAid in the USA refer to
Otherwise refer to for customer service.
You can also try for United States, District of Columbia, and Puerto Rico, call toll-free 1-800-541-6390. For Canada toll-free 1-800-807-6777.
May 16, 2010 | KitchenAid KSM75 Mixer
My refer is at 41 degrees just had the difusser
Maybe your evaporator needs cleaning, I'd check that.
Feb 03, 2010 | KitchenAid KSRS25IL Side by Side...
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
Ksra25i kitchenaid refer ice maker
Probably the infrared emitter and receiver that are on opposite walls just inside freezer door near ice bucket.
Oct 31, 2017 | Refrigerators
KitchenAid model K45SSWH doesn't work
Check and make sure the brushes are in correctly. There is only one correct way. The brushes are tapered and need to go in with the taper bypassing the little notch inside. They hard to see but, they are in there, Good luck.
Dec 22, 2007 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Refrigerator Issues
Great job on the defrost drain fix, it's exactly what we do. Check that the duct damper does close fully when the refer side temps are set to warmest. It could be freezing due to that damper not closing fully or at all. It should only be open to let cold air in until the temp is satisfied then closes again. The temp control in the refer may also be failed so it doesn't know the temp was reached. The bi-metal is only there for a safety device basically to kill power to the heat elements if the defrost cycle runs too long or the area gets too hot. I'd suspect the air damper is stuck open and contstantly letting cold air into the refer side.
Feb 03, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
300 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
