Question about GE WCVH6260F Front Load Washer
Ruining cloths, leaves black stain.
1yr old washer staining cloths, stains are black in nature. checked under seal, area clean. help..thanks
  • Anonymous Mar 18, 2014
    Use only hp detergents, have turned off water saving feature. Hot or cold water does not matter still leaves white powdery stain
  • Anonymous Mar 27, 2014
    Stains shirts
  • 96 Answers
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Posted on Mar 04, 2008
Dark greasy stains after washing
When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail.
The seal wont be difficult to replace,but to get access to it you have to
basically disassemble the whole machine. The hardest part was pulling the agitator off the shaft - I
use a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way - perhaps yours
will be easier than mine was.
Apr 18, 2010 | LG 4.0 Cu. Ft. 7-Cycle Extra-Large...
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Oil stains
Hello
Welcome to Fixya
My name is Huum,
You said, you have been getting oil stains on some of my clothes.
this means your washer has a leaking seal and oils is coming out onto your clothe.
Water is getting into the seal and bearings.
Do not waste any time. Get service out there right away.
If this is caught early you may have a chance to save a lot of money!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Leaves
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
Mar 22, 2008 | Whirlpool LSR7333 Top Load Washer
Detergent stains on the finish of the washer and dryer
Try one or all of the cleaners listed below to remove the stain. Hope this helps you.
  • Oxygen bleach
  • Rubbing alcohol
  • White vinegar
  • Baking soda
  • Hydrogen peroxide
  • Acetone
  • Paint thinner
Steps to Remove the Stain:
  1. Laundry soap dyes are usually more difficult to remove than other colors.² However, oxygen bleach, such as Oxi-Clean, can sometimes clean away even the red stains. Sprinkle the powder on a damp sponge and scrub away the stain.
  2. Soak a cotton ball with rubbing alcohol and wipe away the detergent stain. If the stain is not immediately lifted, allow the alcohol to soak for several minutes.
  3. Vinegar is effective on many kinds of stains. Make a solution of one part vinegar in two parts water and sponge the vinegar onto the stain.
  4. Baking soda can be effective for removing detergents from appliance surfaces. Sprinkle baking soda on a damp sponge and clean the stain until removed.
  5. Combine equal parts of 3% hydrogen peroxide with water and sponge the stain with the solution.
  6. Soak a cloth with acetone nail polish remover and use it to wipe off the stain. If the stain does not wipe off right away, it may help to lay the cloth over the stain to soak for a few minutes.
  7. As a last resort, wipe paint thinner on the stain. Paint thinner can remove most dye stains. However, you may want to test this on a small, hidden area first to be sure the paint thinner won't damage the lacquer on the appliance or cause any other adverse effects.
  8. Once you have removed the stain, wash the area with soapy water to remove any residue from the cleaning solution.
Jan 06, 2018 | Washing Machines
GE WCVH6260F Front Load Washer Logo
1,346 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
