Question about Casio Exilim EXZ1050 Digital Camera
Date and time
How to I turn off the date and time
  • 374 Answers
If it's already on the picture you will have to crop it out.
To shut it off further pictures go into picture mode and press menu, go to record tab and go down to timestamp and confirm through there.
Posted on Sep 13, 2008
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
May 23, 2018 | Samsung Cameras
How do i turn off the date/time stamp on my camera?
If you do not want the date and time stamp on future pictures, turn it off:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date/Time Stamp feature.
    3. Turn off the Date/Time Stamp feature.
  3. When you are finished, press the OK button.
Apr 02, 2015 | Cameras
Date 01/31/14
Does it keep losing the date when you turn it off? or are you asking how to set the time and date?
If you're losing time and date when you turn the unit off, there's a coin cell battery on the main processor board that needs replacing.
If you just want to set the time and date - Press "SHIFT" and 12 lead keys at the same time. select "7" for date and time, use the return key to select date or time
Jan 31, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
How to turn off time/date stamp on finepix s1850
Seeing the Date When Previewing images
  • The camera records the date and time of each photo in the metadata attached to each picture. You have the option to see the date and time when when the camera is in "Playback" mode, which allows you to preview your images on the screen. When looking at your pictures, use the "Disp/Back" button to include text with your pictures. The date and time will appear along the bottom of the image.
Printing the Date on Pictures
  • Users can include the time and date on their prints from the "Mode" menu by choosing "Print Order" with the "With Date" option.
Aug 22, 2012 | Fuji FinePix Cameras
I have a Tissot Automatic PR 516 from the early 70s. Time is kept well. Date moves forward correctly but it is the wrong date. I am unable to turn back the date. I am able to turn back the day. Any...
The crown wheel (winder) should have 3 positions, (1) the normal winding position (3) fully out; at this position the watch stops and the time can be adjusted.
(2) This position is between the 1 & 2 and is used to adjust the day and date. If you wish to change the date by winding the crown backwards or forwards.
Since watches can very a little, if turning the crown when in position 2 the date does not change, pull the crown to position 3 and turn the hands until you pass the midnight position, when the date will change and then re-set the time. If you wish to advance the time more than one day, when it changes, wind the crown backwards past the midnight position and then wind it forwards again. Repeat until the correct date is showing and then re-set the time. The exact distance you need to turn the crown to change the date will have to be found by experimenting!
Feb 06, 2011 | Watches
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
Setting time and date
Hi. Turn key to Program mode. Type new time in 24hr format Press X/DATE TIME button Press Clear (C) Then enter date as YYMMDD Press X/DATE TIME button Press CLEAR (C) Turn key back to REG mode
Jun 04, 2009 | Casio Parts Cash Register PC Desktop
Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
Mar 25, 2009 | Motorola Cell Phones
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Casio Exilim EXZ1050 Digital Camera Logo
71 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
