Epson FX 1170 Matrix Printer
Problem for Epson FX 1170 Matrix Printer
LED BLINKING
By Baba1 on Dec 11, 2007
When i'm issue print order some time it prints some text like one word, one line or max 2-3 lines the three LED's are blinking simulteniously.
Same Problem
Feb 27, 2008
-   When i'm issue print order some time it prints some text like one word, one line or max 2-4 lines the three LED's are blinking simulteniously.-   Guest
Solution #1
posted on Aug 22, 2008
Not Rated)
MadBindus
Rank: Guru  Epson Expert
Rating: 88%, 134 votes
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
If the issues persist
Please read through these instructions before trying and then follow the steps below:
1. Please power the printer "OFF".
2. Remove the printer cable from the back of the printer and remove all the paper.
3. Hold down the "LOAD/EJECT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "LOAD/EJECT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer "OFF".
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth across the width of the carriage several times. Reload the ribbon and the paper and try your test again.
Was this helpful?
Yes
No
Solution #2
posted on May 03, 2008
Not Rated)
AntonioCirio
Rank: Wiz
Rating: 83%, 86 votes
Replace the communication cable (parallel cable).
Was this helpful?
Yes
No
Popular Solutions for Epson FX 1170 Matrix Printer
Questions and Unsolved Problems for Epson FX 1170 Matrix Printer
Do you recommend Epson FX 1170 Matrix Printer?
Answer
Answer
when printing to my FX-1170, the very first character is always incomplete. After that all... (More)
Answer
While printing it shows the error message saying Cannot find file TVSE9.DRV
Answer
i'm trying to make my epson fx1170 matrix printer work normally. When I click the print option, the... (More)
Answer
My FX 1170 prints unidirectionally, that is, the printhead will return to the leftmost part of the... (More)
Answer
I have Epson FX-1170 dot matrix printer. Don't take the paper with beep sount continuosly when i... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
