Question about Maytag Refrigerators
Filter light stays red even after replacing filter
    President:
  • 1,015 Answers
There is a way to re-set the filter light. You usually need to push in two buttons together or one button for a number of seconds. Look for something that has a filter reset indicator or button on the fridge.
Posted on Sep 13, 2009
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
On this Frigidaire water filter system, there is a filter state light, wich was red when i bougth the frige second-hand, changed to green, when i changed the filter, normal, but it stays green, even after...
HI, if yours is similar to mine with ice maker and gets used several times a day my light comes on about every 6 mo. but i do have three kids so i use a lot of water. depending on use it could last 11 mos. but i would not go past a year if not used as much.
Mar 12, 2011 | Refrigerators
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Filter Light
Do not purchase this refrigerator in the future.  It's terrible performance and needs constant repairs.
Apr 07, 2009 | Jenn-Air JCD2389G Side by Side...
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
Jan 30, 2009 | Plumbing
Water filter light won't reset itself
look closely at the panel it will state which buttond to hold for 3 secs to "reset " filter light
Jan 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
