My washing machine will not hold water
My kenmore washing machine will not hold water . it keeps wanting to fill, which means the water will not stop running, because it is draning out the bottom.
    President:
  • 1,776 Answers
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Posted on Sep 13, 2009
Washer not is use fills with water? why?
It is kind of the opposite of these tips...instead of the dirt stopping off the water, the dirt is stuck in the valve and holding it open...
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 16, 2010 | Kenmore 44102 Front Load Washer
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
May 03, 2010 | Kenmore Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore washer will not shut off the hot water at the end of the fill cycle
Water valves work on a hydraulic principle, the surface area of the valve where the water comes to the valve is more than the opening that it passes into the machine.. The pressure of the water shuts off the valve. The electric solenoid opens the valve when power is applied to fill the machine.
If you unplug the washing machine while it is filling and it keeps filling you have a bad water valve.
If you unplug the machine while filling and it stops filling you have a electrical problem or a bad pressure switch.
Jan 09, 2010 | Kenmore Washing Machines
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Washing Machines Logo
939 people viewed this question
Top Washing Machines Experts
