Question about Garden
I have a honda xrx 217 mower. the left rear height
I have a honda xrx 217 hxa mower. the left rear height adjustment is stuck and ddoesn't move. how can i replace that? f
    New Friend:
  • 93 Answers
Just spray it where it adjusts with WD-40 or better rust remover. Get good stuff at your Auto Supply Store. Let it work overnight and your problem should be solved.
Posted on Sep 14, 2009
My blade adjustment lever is stuck in the highest position
Hi Cindy:
Blade height is achieved by raising or lowering the deck so it sounds like you really only may have one problem.
If the height adjustment lever is stuck and will not move, it should be fairly straightforward to look at the various components to see where it is binding, and then make corrections as necessary.
Safety First. Have the engine OFF and the key removed before you start exploring the bits.
Cheerfuls.
Sep 24, 2015 | Garden
How do ichange cutting height on honda petrol lawn mower
There are loads of different arrangements - the most common is a lever sticking out of the read of the machine that adjusts the height of the roller, and 2 adjusters for the front wheels.
Oct 05, 2014 | Honda Garden
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Honda lawn mower not pulling hrx 217
Clean pulleys, replace belt.
May 21, 2012 | Honda Garden
How do i lower the cutting height on my honda hrb 476c mower
You either have hand adjusters that allow you to put wheels at desired height ,or you would have to unbolt your wheels from the deck and place them at your desired height. The deck would have a number of holes in it for just this purpose. GOOD LUCK.
Sep 15, 2011 | Honda Garden
I need to know how to set the mowing height and do not have a manual
Almost all mowers' cutting height is adjusted by little "tabs" at each wheel. The tabs need to be pushed in to adjust.
May 03, 2010 | Black & Decker 19" Electric Lawnhog...
Height adjustment on my lawn mower
have the mower on a flat suface and adjust for the height you need on all four wheels then raise the rear of the mower by one hole to give clearance and reduce the loading on the blade
Sep 12, 2009 | Garden
Adjusting the wheel height
its in the left side at the back end. a plastic orange color lever that you have to press up while pushing the mower up or down
May 25, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
