Question about Dell A920 InkJet Printer
I can't get the watermark on a contract to show up when I print it on my Dell A920 All-in-One (with Windows XP).
I connected my laptop with my dell A 920 and on my computer when i look to add printer it is not listed. It does nto print at all, i guess it is not recognised
You have to install the printer drivers. Click here to download the driver for DELL A920. Select the driver file according to your Operating System (e.g. Windows XP). After downloading the file, just double click it and follow the on-screen instruction. This will install the printer and you would be able to print.
Good Luck!
Hope this helps!
CreativeTECH
Dec 13, 2010 | Dell A920 InkJet Printer
My dell a920 printer won't print with windows 7
Hi There
Not no if you may have the wrong driver, this one is for Vista and most Vista drivers will work on Windows 7 gave it a go.
I have put a driver for you on my website for you it for windows Vista to download just click on the driver link and it will download for you, best to save it to your desktop so you can find it.
Link = http://www.4all2sell.com/driver/Dell-A920-Vista.exe
After you have downloaded it just double click on the icon Dell-A920-Vista.exe and follow the instructions to run the.
Please call back to say if it works for you Thanks
All The Best: Pineworks
Feb 11, 2010 | Dell A920 InkJet Printer
I HAVE PROBLEM IN ISNTALLING A920 DELL COMPUTER
i found this website that iwill give you a patch to help you install on windows 7http://en.community.dell.com/forums/t/19306980.aspx
Jan 03, 2010 | Dell A920 InkJet Printer
Misplace CD for Printer A920; need to download if possible without CD
You can find the driver for the Dell A920 printer at:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&os=WLH&osl=en&catid=&impid=&SystemID=PRN_ALL_A920
If your operating system is Windows XP, you can download the driver directly from that page. If you have Windows 2000 or Windows Vista, you can change the operating system at the top of the page to get the correct download.
Mar 23, 2009 | Dell A920 InkJet Printer
Networking a920 printer with vista
The Dell A920 all-in-one is only compatible with Windows 2000 or Xp, if you are using Vista you will need a different system.
Jan 02, 2009 | Dell A920 InkJet Printer
Dell A920 with Windows Vista
For a Dell A920 (Personal All-in-One), pls download OS appropriate driver(s) from here. Pls select Vista, thereafter, install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 21, 2008 | Dell A920 InkJet Printer
No print
replace cart. first with original.
Dec 18, 2007 | Dell A920 InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
