Question about Samsung HLP4663W 46" Rear Projection HDTV
TV emits load humming sounds when operating - Samsung HLP4663W 46" Rear Projection HDTV
    President:
  • 788 Answers
Your symptom sounds like failing color wheel.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky.
If you want to try this repair yourself you can obtain the part from many places. You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 13, 2009
  • 4,472 Answers
This sounds like a problem with the color wheel. The part is about 110-200$ depending on where you purchase it. These only last so long because they spin at high rpms and that is why you hear the noise. Better to have it replaced before it breaks and possibly does more damage.
Thank you,
Lee
My sharp aquos has speakers on side of TV. the speakers are worn out and emit a low humming sound that disturbs the audio ? how can i solve the problem
A hum in a speaker is usually a bad connection on an audio jack, this allows interference to enter the audio signal stream Check all the connections and cables. Swap cables if you have the ability. If that does not reveal the source of the problem, you may have a component on the power supply that filters line noise that is going bad.
Oct 18, 2017 | Sharp Televison & Video
Why does my 2000 Nissan Quest emits humming sound when engine run
Most likely, that is the sound of the FUEL PUMP. If the car is running well, don't worry about it. Try changing your fuel filter to see if that helps (usually does).
If you have trouble with fuel delivery at high speeds or under load, suspect that your fuel pump is about to fail.
May 16, 2015 | 2000 Nissan Quest
Coby 32" led buzzing on hdmi input
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind
Apr 05, 2014 | Coby Televison & Video
Bose solo only emits a humming sound, no voices or music
The audio output section circuit have the fault. Shorted [damaged] output IC can cause this fault. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 09, 2014 | Bose Solo TV sound system - Black
Clicking sound when you plug it in. picture won't come on
Plasmas are notorious for a slight humming or buzz that emits when they are on...
A clicking sound when plugged in isn't nececessarily bad. However, the picture not working is bad and this may require a technician.
Are you using the proper power cord that came with your tv? Are you able to use the included remote or use the power buttons on the television itself?
Has the tv been moved or dropped recently?
Dec 24, 2013 | Philips 50PFP5332D 50 in. Plasma...
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
Got a humming/ buzzing sound from speakers. When muted no buzzing but when turned down to zero, buzzing. Can't shut off speakers. What to do?
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 27, 2010 | Apex Digital LD4088 LCD TV
Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Mar 16, 2008 | Audio Players & Recorders
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Samsung HLP4663W 46" Rear Projection HDTV Logo
164 people viewed this question
Jerry Greenberg
Jerry Greenberg
