Question about Kenmore 63942 Dryer
Kenmore Soft Dry,
The dryer does not start anymore. I do not hear any buzzing etc. My lint catcher is clean also. The model/ stock number is...87873100. What series would this be considered. I looked up on the internet and could not find out.
Thanks, Chris.
  • 430 Answers
Try popping the lid and inspect the belt. I did one for friend. On his when the belt broke, the dryer quit. It has a built in safety switch. Sorry don't know the series. His was 15 years old plus...
Posted on Sep 13, 2009
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
How can I remove the front of my dryer so I can clean out the lint? I have a brush, but it can not unclog the large amount of lint once the lint catcher is removed. Model is 110 60922990
one of the most effective ways to get this lint is to use your vacuum cleaner hose and reduce the size down using heavy plastic tubing, of a small enough outside diameter. Many sizes of plastic tubing are available at hardware stores, home depots, etc. Be sure to get a thick walled tubing that will not collapse under the suction. good luck with it.
Oct 25, 2009 | Kenmore Elite HE4 Electric Dryer
Flame goes off
First make sure that your exhaust pipe going outside is completely clear. Also you may need to clean the lint out of the drier. If you take the lint catcher assembley off on the inside, ther will be alot of lint inside. Just clean out what you can by hand, then vacuum out the rest. This should take care of your problem.
Jun 03, 2009 | Kenmore 74602 Gas Dryer
I have a kenmore gas dryer 110.74832400 doesnt heat
You stated you checked all lints roblems. Just to make sure. Did you remove the lint catcher completely on the inside? If not take that off and clead the lint out of the inside of the duct. Also lint can build up inside the lint duct on the rear of the drier and in the duct going outside of your home.
Jun 03, 2009 | Kenmore 75962 Gas Dryer
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Kenmore 27 inch wide electric dryer
Can you turn drum by hand? If so you probably need a motor.
Nov 19, 2007 | Dryers
Kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
