Question about Acer Computers & Internet
Power button on my acer tower will not work. How do I get it to turn on?
    Top Expert:
  • Acer Master
  • 53,656 Answers
Replace the power button.
Posted on Aug 25, 2019
SOURCE:
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Tower turns on, but not the monitor or the keyboard
There seems to be a problem with the motherboard. You need to get your hardware checked.
Alternatively, there is a solution that worked every time for me.
Disconnect The A/C Cord or Charger from the laptop,
Remove the battery,
Hold the Power Button for 45 seconds.
Put everything back together and then try!
Tips : Use a cooling pad or a hard surface to keep your laptop on. Sometimes this problem occurs due to improper ventilation & overheat problems.
Good luck !
Feb 14, 2013 | Acer Computers & Internet
I need a picture of what the insides of the tower looks like a plug fell out
Tell me what is the wire color ? it should be nothing other than the LED light / reset / power button.. Just confirm me if all the front panel buttons are working ?
this is the motherboard picture but it wont help unless you find what is not working in ur pc - https://www.blueraven.com/BlueRavenResource/ItemimagesLegacy/Z3807-0.jpg
Jan 28, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
Acer Veriton 6900 Desktop says no signal and the screen turns off. The towers power light stays on but the fan isn't running.
Change the power supply and restart your pc. This will happen when the power supply has gone bad. It sends power to low voltage items but not the needed voltage to power the system on.
Good Luck
C2Solutions
Feb 14, 2012 | Acer Veriton 6900 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hello, i have a problem with my PC Model: Acer Aspire M7200 (Desktop Computer.) . I left it running over night and this moring i woke up and the power button was flashing blue, and dosnt turn on. I dont...
    Hi gatisd2
    PLEASE RATE MY ANSWER IF YOU FOUND IT HELPFUL
    I think its gone into power save mode my does that i pull out my power cord from the tower wait 30 seconds then plug it back in....See if that helps (TURN OFF ALL POWER SUPPLY FIRST)
    Jan 30, 2011 | Acer Computers & Internet
    Veriton 7200D ACER - I went to turn on my computer today and it wont turn on. On the front of the tower there is a green light flashing intermittently. Looking at the back of the machine I see that the...
    Press and HOLD the ON/OFF button for TEN seconds, until the computer turns itself off.
    Then, press the ON/OFF button as per normal, and it should start.
    Sep 27, 2010 | Acer Veriton 7200D PC Desktop
    I have an Acer X1700 desktop - 3 days old by the way. Runs Vista Home Premium. 1 day after arrival, pushed power button. Monitor light is blue, flashes the Acer logo, then says "no signal" and blue light...
    I would get ahold of acer. It should be under warrenty. sounds like a hard drive issue to Me. Just because it is new doesn't mean it was right from the start. My neighbour had the same problem with his acer. I told him to but a dell or hp. good luck.
    Apr 27, 2009 | Computers & Internet
    Computers & Internet Logo
    18 people viewed this question
    Ekse
    Alun Cox
