My D52W20 emits a high pitch sound through both speakers. Gets louder if I raise the volume, quieter as I lower it & goes away if I mute the TV. The picture is perfect, audio from the TV show is Ok
SOURCE:
nfandres
  • 168 Answers
SOURCE: High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Posted on Feb 26, 2007
  • 192 Answers
SOURCE: high pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
dsacco86
  • 1077 Answers
SOURCE: Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Posted on Feb 26, 2009
SOURCE: RCA Guide Plus Gold Gemstar 27 inch Entertainment
how do I hook up a wii to my 27 inch rca guidegold gemstar plus. I use the inputs on the rear and can't get the tv to recognize them.
Posted on Jan 01, 2011
rulds2008
  • 3866 Answers
SOURCE: No audio on Sony Wega
Hello, Welcome to Fixya.com
If the mute is ok, you want to check if your have a cable or sat box that the mute on those are ok as well, if so then your looking at a internal issue with the TV that would involve repair.
Try this
1. unplug the tv wait 10-15 seconds then plug it back into the wall outlet.
Also
2. unplug any cable boxes or sat boxes that might be causing the issue.
If you still are having issues you might want to check it into a local repair shop near you, but take this advice for what its worth you might wind up paying more for the repair then the purchase of a nice flat panel.
Make sure if you do take it into a shop that there registered with the BBB and do not have complaints registered as those shops could end you paying more money.
Thanks for making Fixya your first choice, We can Fix most things but have solutions for everything.
Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Mar 22, 2011
There is a constant high pitched sound coming from channel A on my PV2600 amp, what could it be?
It sounds like one of the equalization or high filter circuits failed in the amp. Have it repaired.
May 19, 2014 | Audio Players & Recorders
Sound Issue
This might be of the core vibration of the backlight inverter transformers.
Dec 09, 2012 | Televison & Video
Sound is too low
Go to START>Control Panel>Sound HQ/Sounds and Audio Devices or something similar. Make sure your speaker volume is up (Move the sliding tab to the right). And that your Speakers Volume is up(A tab on the bottom area of sounds, in advanced tabs, or properties. Slide the tab to the right for louder, left for quieter) and make sure your Mute button is UNCHECKED.
Have a good one :)
Jul 24, 2010 | Polk Audio AMR2 Computer Speakers
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
The volume on my tv is stuck to number 22 it will go lower(quieter) but not higher (louder)
There is 2 transister between Microprocessor and speaker.. See the circuit diagram..Volume + transister is lost his gain,replace the transistor and get it up..
Jul 09, 2009 | Televison & Video
Monitor making humming noise
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Jan 31, 2009 | KDS Visual Sensations 190i 19" CRT Monitor
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Ekse
