Question about Car Audio & Video
My fusion fcd 255
When i push eject my front pannel will not come down or it will not eject the cd. it was working fine yesterday?
Easy just disconnect car battery and wait 2 min and re connect and the stereo will restart and it should now properly eject the cd , happened a lot to me.
Posted on Jan 26, 2008
  • 23 Answers
Hi G,
Do you hear any noise? like its trying to eject the disc? If you cant hear anything try using contact cleaner on the back of the faceplate, on the contacts. If you still cant hear anything, Id say the motors shot, and that not a self fix. By the looks of it, it seems like it just came out, if its still under warrenty, id exchange it for a new one. Good luck
CoDoc
Posted on Dec 12, 2007
First@gmail.com, 2006 malibu cd player keeps the cd, doesn't eject or take the cd, but plays fine. Is there a part I can replace myself?
Is it a burned CD-R? I know (this is probably the same on a 2006) that on my 2005 if you put one in, it will play fine then lock the disc in. There is a fuse pannel on the passenger side on the center of the console towards the front of the car. Just pull the plastic cover off. Find the 10A fuse by the little grey box, and a blue and white circle. (or just look for the fuse labled "RADIO" on the map inside the plastic cover and then locate it in the fuse box). Turn the key off, pull the fuse, turn the key back on for a sec and the radio will not come on. turn the key off, put the fuse back in and turn the key on. the disc should either come out or you will have to push eject. This may or may not work, some people say it doesn't work for them. (this may reset the radio number buttons memory). Hope this helps!
Aug 21, 2011 | 2005 Chevrolet Malibu
Can't Open FCD File
The FCD file extension is associated with Virtual CDROM. The .fcd files contain uncompressed backup image file format.You need to download an application that can open this type of file extension.
May 21, 2011 | IMSI CD Copier Gamers Edition 1.0 Full...
I have a 2008 ford fusion. i just loaded a cd into in dash cd player and it now comes up with a "load error". i tried to eject it as well and it tells me "eject error'. it took my cd but it...
See if the cd is not fully inserted, take another cd and gently try to put it into the cd player to push any stuck cds back in. If this does not work you will need to replace the radio.
Feb 28, 2011 | Car Audio & Video
I cant eject my cd
There is a indent in the front of the face of the radio. Try to push it with a sharp pencil or pen. It might reset the cd part and eject button might work again. If not you may have a cd stuck in it then you can try get tweezers and pull it out or a credit card and try to straighten it out. Those were some of the techniques I used when I was an installer for 12 yrs.
Apr 07, 2010 | Sony CDX-M630 CD Player
The CD player/changer in my car is not loading or ejecting the CD's. When I push the load or eject button, it makes a grinding sound. It was playing fine yesterday but since I left a CD inside the CD...
I just acquired the same problem. I tried to put a new CD in and it wouldn't take it. I ended up pushing it in when I was trying to get it back out and now it won't play the CD, or eject it. I think it could be stuck between tracks, but they want $188 to look at it and fix it even if it is a simple fix. I am looking for suggestions also, Diane
Mar 13, 2010 | 2003 Mazda Mazda6
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
Battery died - replaced the battery yesterday but now the 6 disc changer will not operate - radio and clock work fine but it's like it does not even know there is a cd player in the car. every 30 seconds...
I take it the cartridge will not eject
If so press and HOLD eject button insert credit card or similar under cartridge push firmly in and move left/right
This locates micro release switch
Make sure nobody has inserted discs upside down
Nov 20, 2009 | 2005 Dodge Durango
CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
Jun 19, 2009 | 2003 Mazda Mazda6
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
228 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
