Question about The Computers & Internet
Water leak but not coming from water pump or thermostat
I don't know the name of the part but it’s the part the heater hose is attached to .
    Top Expert:
  • The Master
  • 28,956 Answers
Take a picture of it
Posted on Aug 25, 2019
Testimonial: "I have a picture but it’s on my iPhone and I am on my iPad so trying to find it Steve"
SOURCE:
brainyass
  • 242 Answers
SOURCE: 2002 chryler sebring is leaking anti freeze
It depends on where the leak is coming from. If the water pump is leaking, it has a hole on the bottom of it. You will see a trail of dried anti freeze coming from the bottom of it, indicating a bad water pump. It's best to dry everything off, crank it up and let it come to operating temp and check for where the leak is coming from. It may just be an old hose or loose clamp.
Posted on Nov 20, 2008
Mike258
  • 1498 Answers
SOURCE: 2000 Jeep Grand Cherokee Limited
Hey there Dave,
Had the same thing happen to my Wrangler about three years ago.
It was the weep hole too.
I drained the coolant, dried the weep hole and plugged it with a small amount of that solid epoxy they market to fix holes in gas tanks. I refilled the radiator and the plug held.
It's still holding.
Just an alternative option
Mike
Posted on Nov 26, 2008
SOURCE: 2002 pontiac grand prix over heating
Are your electric fans engaging or turning on?
Posted on Dec 26, 2008
  • 35 Answers
SOURCE: my 1995 dakota is overheating, replaced water pump, thermostat, fan. What to do????
if the fan is working properly, the only thing left to check is the radiator...
i may be clogged or damaged so the water can't travel in it properly...
Posted on Apr 29, 2009
dmftrucker
  • 1922 Answers
SOURCE: bad leak, dont know if its water pump or thermostat
sounds like your water pump gasket has a hairline crack in it and as engine warms it expands and leaks more
Posted on Sep 28, 2009
My 93 Mercury sable is leaking all my coolant, I don't know where it's coming from.
You need to have a mechanic inspect for the leak. It could come from a hose...radiator...water pump...head gasket...intake gasket..thermostat housing... frost plug just to name a few
Aug 03, 2015 | Mercury Cars & Trucks
How to new when my water pump is not movihg water.
You won't know if the water is moving unless you removed the thermostat, the thermostat will remain closed till the car heats up and then water will flow through your raditor.
Water pumps always spin! Unless you belt has come off it will be spinning, What happens to water pumps is they will end up with a bad bearing and will get hot. There is a small hole in the bottom by the bearing that will eventually let the water leak out to keep that bearing from melting and seizing up. If you are not hearing any grinding noises or squealing or water leaking your pump is fine.
Aug 05, 2014 | Metra Ford F 150 Truck 1996 Up
Antifreeze leaking onto belts don't know where it is coming from. Is it the water pump or the water outlet? changed the hoses
What you need to do is pressurize the cooling system, then you should be able to see where the leak is coming from.....There is a tool that does this pressure test.
Mar 30, 2012 | 1995 Mercury Villager
I have a 2000 saturn sl1, and i seem to be putting coolant in my car at least 2 times a week. It also overheats and when it does, it comes out of the top of the part that hold the coolant. Could this be my...
If it is coming out of the top of the radiator, you are getting back pressure. First, make sure there are not puddles under the engine where the water pump is at. If so, you will need to replace the water pump and gasket; as well as the thermostat. It sounds as though the thermostat is stuck closed - replace it (if no leaks from water pump) and see if this fixes the issue.
Also, start the car (radiator full) and let run to operating temperature. Feel the top radiator hose - if it is not hot, but the engine is, then the thermostat IS stuck closed. Be sure to ask for a thermostat housing gasket when purchasing the thermostat, as they do not always come together.
Please let me know if you need further assistance.
carsandcomps
Aug 20, 2011 | 2000 Saturn SL
My friend's 04 Denali 6L is leaking coolant. I
probably the water pump. front and center of the engine, the pulley that may or may not have the cooling fan attached. from under the truck a leaking water pump usually leaves some coolant residue on the timing cover and at the front of the oil pan where the wiring harness come across.
Jul 27, 2011 | GMC Yukon Denali Cars & Trucks
Leaking behind water pump
If it is leaking behind it, you will need to replace the water pump and gasket. The new (can purchase a remanufactured pump, cheaper) pump will (should) come with the gasket.
Please let me know if you need assistance with removal and installation.
carsandcomps,
Guru, Premium Expert, Phone Support @ Fixya.com
Jun 09, 2011 | 1988 Mercury Grand Marquis
98 Ford Explorer SOHC 4.0 V6 Water Leak
take it to a mechinc shop and have them do a pressure test
May 16, 2010 | 1998 Ford Explorer
Water drippinjg from above serpentine belt where lower radiaotor hose connects. water is not coming from hose coming from the silver piece
That is your thermostat gasket. Easy and cheap to replace. If you do it you might as well just buy a new thermostat since the cover will be off and they are cheap.
Jan 18, 2010 | 1996 Oldsmobile Cutlass Ciera
Bad leak, dont know if its water pump or thermostat
Sep 28, 2009 | 2000 Pontiac Grand Am GT
I have a coolant leak coming from the front of the engine. looks like it is leaking around the cam shaft pulley. The vehicle is a 2001 Nissan Frontier v6
Sounds like either the water pump or the thermostat housing. The water pump has a small hole in the bottom where the shaft comes through, when the water pump gets worn it will leak here so you know to replace the pump. The thermostat housing will be at the motor end of the upper radiator hose where it attaches to the motor. Hope this helps.
Aug 11, 2008 | Nissan Frontier Cars & Trucks
Computers & Internet Logo
186 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
