Question about Sharp Computers & Internet
Sharp R-510AK numeric keypad timer buttons not working
Some of the numeric keypad numbers which set the amount of time no longer respond to touch and do not work.
    Top Expert:
  • Sharp Master
  • 53,785 Answers
The keypad has become defective over time.
Posted on Aug 25, 2019
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Sharp R-510AK Microwave Oven Fuse Blows
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • 43 Answers
SOURCE: Numeric keypad stopped working.
Press Num Lock above numeric 7 and see if the Led of your keyboard turn on. Hope it help.
Posted on Mar 17, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We regularly repair these control / display units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 31, 2009
SOURCE: Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Posted on Mar 06, 2010
SOURCE: my samsung s8300 mobile touch
i bought this and solved the problem. NIKOS GREECE...
http://cgi.ebay.com/Samsung-S8300-Repair-Part-Ribbon-Flex-Cable-Tools-/380284533936?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D738272505495324217
Posted on Jun 18, 2011
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
My number keypad has stopped responding how can i fix it please
Hello and Welcome to FixYa!
If your numeric keypad is not working please first make sure that the numeric lock button (may be a light too) are on. Try to press the numeric lock button once and then use the keypad. If this doesn't work try pressing it again.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Computers & Internet
How do i change the number of rings for xerox workcenter 123 to pick up for receiving fax
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Fax Mode Settings]. The Fax Mode Settings screen will be displayed.
  7. Select [Fax Defaults]. The Fax Defaults screen will be displayed
You wll then see locations to set the amount of rings to answer, ECM mode etc.
Jul 23, 2010 | Xerox WorkCentre M128 Copier
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Dec 11, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
R-9h81 sharp microwave oven
I'm sorry, but the keypads for for Sharp R-9H-type models are no longer available.
Please don't kill the messenger, but unfortunately, once the oven becomes unusable it will have to be retired.
Sep 06, 2008 | Sharp R-930AK Convection/Microwave Oven
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Computers & Internet Logo
15 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
