Question about MTX Audio Tna251
My amp had 3 red lights on yesterday now there is only 2 so i un hooked my speakers and now no loghts come on its a mtx tna251 terminator amp. What dose this mean
  • Tim Compton Aug 25, 2019
    It was working fine untill the other day
    Genius:
  • 1,659 Answers
Sounds like issue with speakers or wiring. Hook one up at a time and see if lights come back on.
Posted on Sep 12, 2019
    New Friend:
  • 137 Answers
CHECK YOU CONNECTION YOU MAY HAVE PUT WIRE TERMINAL WRONG AN THE AMP GOES TO PROTECTION CHECK ALL SPEAKER TOO
SOURCE:
SOURCE: 2 red lights after x clamp replacement
It means basically that the xbox is starting tio overheat fast. what sometimes happens is those x-clamps have to be tightened in a sequence and tight as possible but not too tight to crack the board or cut the small PCB traces. Open up the console again and just have a look underneeh the motherboard make sure there are no torn green pcb traces ( put simply green lines that connect to a silver blob of solder ) and make sure the screws are tight enough.
Posted on Dec 11, 2007
jrw4u
  • 62 Answers
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
Posted on May 01, 2009
etirbynnor
  • 655 Answers
SOURCE: i have a mtx thunder 1501d..i have the power cord
Hello tonytone54, The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it. Hope this helps.
Posted on Jun 03, 2009
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
nate6556
  • 103 Answers
SOURCE: MTX Terminator Amp...Red light comes on when it should be green.
its just a power light to let you know its on
Posted on Jul 25, 2009
I bought a mtx terminator amp model no TNA251 600 watt and two subs installed. It works good for few days but now its not cranking up proper bass and sound. It always has three solid red lights everytime....
does it do this all the time when you turn it on? any sound at all?
provide more information, but my guess its that the amp is blown. replace it or sell it for parts.
Nov 11, 2013 | Car Audio & Video
MTX tna251
I have the same sub combo. The problem is the amp is underpowered for the 2 MTX 12s, get a bigger amp and you should be fine.
Nov 13, 2011 | MTX Car Audio & Video
What is the HLI port on the MTX tna251 amplifier?
Jul 15, 2011 | Car Audio & Video
How do I wire my 12inch mtx ts 55 subwoofer two outlets red with red and black with black or red and black and red and black
The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Jun 17, 2011 | MTX TS551022 Car Speaker
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
MTX Audio Tna251 Logo
22 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
