Question about Microsoft Xbox 360 Console
2 red lights after x clamp replacement
I just replaced the xclamps in my 360 turned it on and it flashes 2 red lights wat dose this mean
    Sergeant:
    Champion:
  • 285 Answers
It means basically that the xbox is starting tio overheat fast. what sometimes happens is those x-clamps have to be tightened in a sequence and tight as possible but not too tight to crack the board or cut the small PCB traces. Open up the console again and just have a look underneeh the motherboard make sure there are no torn green pcb traces ( put simply green lines that connect to a silver blob of solder ) and make sure the screws are tight enough.
Posted on Dec 11, 2007
My xbox 360 colors are all messed up for example the color red looks brown and the color pink looks white PLEASE HELP ME!
This sound like intermittent connections form the G.P.U.
color feed data lines to the ANA/HANA (video chip driver)
This is normally accompanied by poor resolution ,dots , lines,
and finely 3 red lights
You have 2 viable options
1 Have a shop re-flow the G.P.U. and then properly clamp
it to the P.C. board .Cost will very 60.00-80.00.
and ask for their track record and if they replace with
the x clamp with screws and washers take your console
else where . The xclamp must be replaced with supporting
hardware. screws alone will flex and damage the P.C. board
2 do a conservative x clamp mod this will get your console
working but this type of repair normally last 2-5 months
3 And there always Microsoft but there repair service is sub-par for the price
if you have any questions feel free to ask
Rob
Feb 07, 2010 | Microsoft Xbox 360 Console
2 red light error heatsinks wont heat up
2 red flashing lights means your console overheated you just needed to let it cool and or check the fans and other cooling components, and by the sounds of it not heating up you have cooked the chips by trying to fix it so you console is basically a paper weight now, sorry
Nov 13, 2009 | Microsoft Xbox 360 Console
Got a flashing red ring what do i do???
If you have four lights don't worry. It just means some sort of problem with your A/V cord. 3 red lights is the famous "Red Ring of Death". Microsoft has an extended 3 year warranty for it and shipping's on them. If you don't have the warranty, try the Xclamp replacement trick if you're good at fixing things.
Nov 10, 2009 | Microsoft Xbox 360 Console
My 360 has 2 red lights which usually means its overheated but after letting it cool all day it still doesnt work
The X-Clamps at the bottom have come loose. You need to open it and do the xclamp mod.
Jun 15, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
2 red rings after the xclamp fix
Yesh...4 red lights means you didn't have the component or hdmi pluged into the system and tv. 3 lights means there is some soldering problem in your 360. 2 lights means your 360 is overheated. For the 2 lights normally you can fix that with letting it cool for a while and give it some room around the system to run cooler. However by using the towel trick you you caused the soldering to run and now it's probibly miss soldered. I recommend you ship to Microsoft or sell it.
Mar 22, 2009 | Microsoft Video Game Consoles & Games
1 red light
1 red light means general hardware failureand it is pretty much the same as 3 red lights but it is has a slightly different problem. if you are under warranty send it of to microsoft. they will repair it for free. if not buy a new warranty for 60 dollars.
Nov 29, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Flashing lights
THere are alot of fixes for this one of them is the XCLAMP which i did and it worked like a charm. But if you still have your warranty then send it in to microsoft. If you want to know how to perform the X clamp email me
May 25, 2008 | Microsoft Xbox 360 Console
Error code 0020
a solution?!ok my suggest is throw away the fuckin' 360 'n buy a PS3.every time i fix that ***** another fuckin code appears.i've had 0102,0001,0020.0133!so the solution is fuckin' the fuckin' Bill Gates 'n all the microsoft./
Jan 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
734 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
