Question about JVC Audio Players & Recorders
Hi. My jvc mini hifi doesn't produce any sound. Does it have anything to do with audio output setup being off? Why doesn't it provide option to select on.
  • JVC Master
  • 4,189 Answers
Hi Honwani, indicates model of the JVC team you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Honwani, indica modelo del equipo JVC del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on Aug 26, 2019
SOURCE:
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
dunnbiker
  • 8546 Answers
SOURCE: No audio on any channel, even in audio setup mode, no audio headp
If you have any of its sound outputs connected to a TV or tape deck do they get the signal? If so, then we know there is sound processing somewhere inside the unit but not emerging to anyplace that requires amplification.
A quick basic check would be to tune an FM station, run an RCA cable pair from the audio output for a tape deck (see the picture at the link) to an analog audio input on your TV. Select that input on the TV and you shouls hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
http://www.onkyousa.com/images/hookup/TX-SR803/detail_tapedeck.jpg
Check to make sure Multi-Channel input is not selected unless that is what you're listening to as it bypasses all other sources analog and digital EXCEPT the tape; and check any Mute or Zone Controls, too.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason. The click I asked about before... when you turn it on does it get a click about 5 seconds later. That would be the protection circuitry turning OFF to allow the amplifiers to function.
I notice it has a Tape function. Make sure it isn't selected as it assumes a tape deck or processor is attached and will only play back what would be coming FROM the tape deck or processor. On my Pioneer receiver it also disables any digital signal processing.
Sometimes when I'm watching TV with the remote on the seat someone moves and something bad happens. It's always some unfamiliar button that gets touched unintentionally. Look over the remote for things like MUTE, Multi-CH, Tape.
Posted on Apr 03, 2009
  • 15 Answers
SOURCE: Sound is good, but guitar input doesn't seem to
Have you tried selecting the option for microphone boost under your sound card settings (If you are using a windows operating system)? Its a check box option.
Posted on Feb 14, 2010
welcomejee
  • 10594 Answers
SOURCE: I have a JVC TH-M606
Please confirm that unit gives sound output on System Connector J1103
I have schematics of this unit and can assist you to hook RCA jacks for all 5 channels output (L+R+C+SL+SR)
Thanks.
Posted on Aug 12, 2010
sfender713
  • 397 Answers
SOURCE: hp mini 110 started with a hp symble and f9=change
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Posted on Oct 02, 2010
Where do I find the audio output on a Sony bravia tv
Hi John,
if you're using the HDMI cable then the sound will be carried via that cable along with the Video signal. If you're connected via RCA's the Stereo output will be the Mini-HIFI jack that looks like the earphone jack on most cell phones. The Bravia also has the option for Optical output.
Aug 11, 2017 | Sony Televison & Video
Hi kindly help me connect led LG Tv output system to a mini hifi MHC-GNZ55D system so as to have powerful sound from TV?
The head unit doesn't have an audio input on it... you could use a tape deck to 1/8" and connect that via 1/8" female to 1/8" female adapter and an 1/8" to stereo cable to connect it to the TV but there will be a level of noise associated with this option due to the components. You could also use an FM transmitter plugged into the 1/8" female adapter.
Apr 11, 2016 | Sony Audio Players & Recorders
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
Sony hi fi mhc-55 no sond
The audio output chip is probably shorted, check speaker wires for shorts just in case, if okay! the audio output semiconductor needs to be replaced.
Mar 20, 2012 | Sony Multi-System Mini Hifi Systems / DVD...
Jan 21, 2010 | Behringer (UCG102) Sound Card
Speakers produce no sound
are your speakers self powered or passive?
Nov 28, 2009 | JVC Audio Players & Recorders
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
No sound
Hello, amp-amp!
The first piece of information we need to find out is whether there is any sound from the 360 at all. When you switch menus in the dashboard, do you hear anything?
Do other games have proper sound?
Which game are you trying to play? Some games give the option to alter what sound setup you are using. If your current sound setup does not support 7.1, 5.1 surround sound, etc.. you will not hear anything.
Go to your dashboard.
Press the Right Bumper until you get to the "System" tab. Select "Console Settings".
Select "Audio".
Select "Digital Output".
Select "Dolby Digital".
Any sound now?
And, as with any audio problem, we need to make sure your audio cables are plugged into the proper jacks. What type of a/v output cables are you using on your 360 (i.e. what color are the tips?).
Thanks, reply back with any information you have, please!
Dec 26, 2007 | Microsoft Xbox® 360 Core System Console
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
