Question about Protron PLTV-32 Television
I have a protron tv Model # LT32C1P1. The problem with the set is that the power light doesn't stay on and it screen doesn't light up. I have no picture and no sound. I recently hooked up my DVR cable box cables rather than the cowaxle cable to the set and start using the PIP features of the TV set.
  • 10 more comments
  • Mr. Denworth Frederick Sep 13, 2009
    The LED light stays on red. When I turn the power on it goes to green for about 3 to 4 seconds then goes back to red. I try turning the supply power off and turning it on again, but that doesn't work.
    Thanks for the answer. At this time I would like to know where the X-sus board is.
    Thanks
    Fred.
    Hello.
    Do know where I can buy the parts for this problem?
    Do you know what part I would need to buy?
    Thanks
    Fred
  • Mr. Denworth Frederick Sep 14, 2009
    I guest you are not going to answer me anymore.
    I think I would rather buy the power pack unit than try to solder/de-solder the specific part.
    Do you know the exact name for the unit or part number I'll need.
    Thanks
    Fred
    Do you know what company makes Protron?
    Fred
    I tried calling the phone # and the email address and both of them failed. Do you happen to know what is the name of the company that made this particular part for protron? If you are able to, give me a call at 917 854 9580.
    Hopeful.
    Fred
  • Mr. Denworth Frederick Sep 21, 2009
    Hi Rylee.
    I am still working on this Protron TVwith the same condition. I bought the entire power supply board from a company on the internet and replaced the one that wasn't working with the one that I just bought. I still have the same problem.
    The red light stay on when pluged in, when the power is turned on the light turns to green for a few seconds and then return toi red. Needless to mention that the screen doesn't light up. I wouild like to know what to do next.
    ramplus@pacbell.net
    Name Code Qty Each Options
    FSP232-4M01, 9OC2320100, FSP232-4M01 1 59.99
    FSP 232W Open Frame Power
    Supply Replacement Unit
    for LCD TV
    (Shipped)
    Fedex Tracking Number:
    434927661516042
    Subtotal 59.99
    Shipping 11.06
    Tax 0.00
    Total 71.05
    Being patient.
    Fred
    Solution #1 posted on Sep 13, 2009
    rylee_smith
    Rank: Guru
    Rating: 87.05% , 733 votes
    Hi
    Thanks for using FixYa. This has happened due to a faulty X-sus board connection with the power supply board or a faulty X-sus board itself. Please tell me the status of the front panel LED light. It can also be a faulty power supply board on your Proton TV. Also check for the ribbon cables between the power board and X-sus board.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Comments:
    Sep 13, 2009 - Hi
    The power supply i was talking about is the internal power supply board. The power supply fails due to swollen capacitors and burnt resistors/transistors on the board. Proton LCD TV's are known for their faulty power supply boards. Please get this checked as this is usually the fault due to which the TV doesn't turn ON. The X-sus board is the vertical deflection board located which is connected to the power supply board with ribbon cables. It is located on the right side when you open the LCD TV.
    Thanks
    RyleeSep 14, 2009 - Hi Fred,
    Sorry for replying late, you can buy the parts for your TV from www.partstore.com, you need to check which parts have gone bad so that you can buy them. If you have electrical expertise and know how to solder/de-solder then you can buy else you can contact a qualified repair tech for the same.
    Thanks
    Rylee Sep 14, 2009 - Fred,
    It seems they are not in business any more. Also checked my database for their customer service number and I would like to recommend you to contact protron as its still not working at:
    PROTON Corporation
    2540 Corporate Place. Suite B111 Monterey Park,
    CA 91754 U.S.A.
    +1-323-980-8292
    info@protonav.com
    Thanks
    Rylee Sep 14, 2009 - Hi
    The specifications of the power supply of your unit are --
    Power Specifications:
    Input: 100-240V, 50/60Hz, 3.0A max
    Output: +24V, 6A; +12V, 3A
    Power Consumption: 100 W typical, 120W maximum
    And, you can buy the power supply unit online from this link--
    Proton 32" LCD TV POWER SUPPLY
    Thanks
    RyleeSep 21, 2009 - Hi
    It can be the signal board, it is labeled on the board a active high or low 5v which sends the command to the power supply. one other trick you can try, isolate the problem use a can of cold spray and hit power supply then the main board, if unit shuts down cold spray will let you see the if the TV ran longer. Please test the power using a multimeter and check for the incoming power on the tuner board and other boards. Also, check for all the connections on boards connected from power supply board.
    Thanks
    Rylee
    I have a protron tv Model # LT32C1P1. The problem with the set is that the power light doesn't stay on and it screen doesn't light up. I have no picture and no sound. I recently hooked up my DVR cable box cables rather than the cowaxle cable to the set and start using the PIP features of the TV More
    I change the power board and I sill have the same original problem. Have any idea what might be next?
    Fred
  • Mr. Denworth Frederick Sep 22, 2009
    Thanks for the suggestion. This seems to be the best advise.
    Will do.
    Fred.
  • 11,896 Answers
Your power supply will need to be replaced. I recommend getting an entire new supply for $30 rather than replacing each capacitor that will cost about $15 + and your time.
Posted on Sep 22, 2009
  • Protron Master
  • 5,138 Answers
PULL the back off look for swollen or puffed up capacitors and if it has a Fan make sure it is clean, you have something wrong in power supply.
Last one I worked on had a diry fan cleaned it and TV came back up running Great. Capacitors that go bad are 1000uf 16v.
  • Protron Master
  • 3,866 Answers
No pic and no sound would be 9 times out of ten a fuse or a power supply unit failure at that point it will need ot be replaced or repaired locally.
If the unit is under warranty please follow standard procedures at that point o get it repaired/replaced. But you looking at a power supply issue there.
Thanks please accept and rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 21, 2009
    Brigadier General:
  • 4,090 Answers
Like many of the new TV's flat screen and rear projection the power boards are made in by sweat shop labour. This forum is constantly asked to solve the same problems many times over and they all relate to no picture no sound after a short time. Power light comes on but nothing after.
If the set is under warranty then claim it.
The z and y sustain boards are fritzed. There will be found a group of capacitors that have either fattened and are about to split or they will be burned. The primary on the power board will allow the power light LED to come one but not fire up the screen. Parts are between $200-300 . However unless you are skilled and understand HT voltage and X radiation from the screen and are then capable of tuning convergence on the pots I suggest a serviceman is employed as their labour and any parts will also have a warranty applied. Many who opt to fix it themselves to save money end up paying double as the boards blow again later because they were either not fitted correctrly or were not tuned. One also has to ask which patrt upline caused the problem in the first place.A service person will be able to check out the total problem not just the obvious and advise you further.
Thanks for using Fixya
  • dennis bullard Sep 21, 2009
    X or z + y there are 3 main boards all linked take a look at all of them for burns and capacitors that appear to have swollen. they may all 3 be affected or just one board. But without the ability to check voltagees across various points and check them against the service manual you are flying at night without lights or radar There may also be some IC chips that are involved. This is why I suggested to get a professional in to diagnose it cotrrectly, rather than dabble around and only get it half fixed. Unless you know what you are doing it is not a DIY
  • dennis bullard Sep 22, 2009
    You can probably now see why this is not a DIY I can only adivise you not to do it yourself! As I said its not just the obvious that causes this, there are problems up and down the line. Even if you changed all the boards there is no guarantee its going to display correctly as some of the boards require tuning to get the pictrure right.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks
Rylee
Posted on Sep 13, 2009
  • 3 more comments
  • Rylee Smith
    Rylee Smith Sep 13, 2009
    Hi
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Sep 14, 2009
    Hi Fred,
    Thanks
    Rylee
  • Rylee Smith
    Fred,
    PROTON Corporation
    CA 91754 U.S.A.
    +1-323-980-8292
    info@protonav.com
    Thanks
    Rylee
  • Rylee Smith
    Hi
    • Input: 100-240V, 50/60Hz, 3.0A max
    • Output: +24V, 6A; +12V, 3A
    • Power Consumption: 100 W typical, 120W maximum
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Sep 21, 2009
    Hi
    Thanks
    Rylee
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
I have a protron pltv 4250. I don't have a remote control and the tv is stuck on pip. so i have 2 screens one shows the tv program and the other screens stays blue. What can I do to fix this...
Few universal remotes will provide functionality to any but the most basic of functions.
PIP only functions properly when being used with HDMI.
I feel you will need to buy a dedicated remote. I found some on Amazon for a reasonable price.
Feb 04, 2018 | Protron PLTV-32 Television
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
Protron PLTV-32C, Model No. LT32C1P1 just went black as we were watching. It did it last night but within seconds the picture came back on. Now it went off and is staying off. Didn't realize at first but...
Mother board Is My Guess That's What's Wrong With Mine And Part Is $250.00 My Problem IS Can I Replace it By Myeslf . I Had Mine looked At .By So Called Professional He Kept it For 8 Months.
Aug 31, 2010 | Protron PLTV-32 Television
Hello, i just got a protron flat screen tv from an estate sale. i try to turn it on, and the light goes from green to yellow and stays. tv did turn on one time before. what is wrong, and is it worth...
Please post back the model so we can help you more.<br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | Televison & Video
Purchased a 32"Protron FLat Screen from SHOPNBC.com and the power light comes on but no picture; now it wont' come on at all.
Your partial resonance power supply IC chip with IGBT switch is bad. On your model of TV it will cheaper to replace the whole power supply module
Aug 20, 2010 | Protron PLTV-32 Television
The power won't stay on.
protron filed banruptcy so that they wont be responsible for selling you a lemon, they covered their asses, theres no solution to their tv or electronic problems, they are a bootlegged company, dont bother calling customer service they are some people in india telling you the same thing every time you call, in other words , they dont even know who protron is, they are paid to say whatever and probably paid one dollar an hour, my tv never worked i bought it from national wholesale liquidators and i suggest no one ever buys anything from this store either, they are a rip off! i lost $900. and sad to say so did everyone else that invested money in protrn/sprectroniq
Sep 08, 2008 | Protron PLTV-32 Television
Protron 32 inch tv
lcdpayless.com has the equivalent power adapter as YHI 090-02180-I3 power supply for the protron TV. link as below:
http://lcdpayless.com/productpage.php?productId=3512
They sold a couple hundred this kind power adapter. it work good.
Apr 09, 2008 | Protron PLTV-32 Television
Protron 32c lt32c1p1 screen
Can you post a picture of this?
Assuming it hasn't affected the operation (yet), you may want to have it corrected because the many cable connections to the display matrix depend on tiny contacts that use pressure to hold them in place. The foam you are talking about is used to support this pressure.
Dec 29, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
158 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
