PROBLEMS OCCUR OF MY COPIER CD6240L SHOWING MACH POSITION OF ENVELOPE SWITCH, I NEED YOUR URGENT HELP PLEASE
3 Suggested Answers
SOURCE:
Smoking_gnu
  • 38 Answers
SOURCE: Need Driver For WindowXP
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2277&modelid=8065
that help at all :)
Posted on Dec 10, 2008
  • 24 Answers
SOURCE: My sharp copier AR-5316 E, is showing error
L4 is a motor lock if you hold down the start key it should give you a sub code 01 main motor, 11, Shift motor, Make sure all jams are cleared out of machine a jam in the fuser/heater section will cause a moter lock to clear code press key #/P-asterisk(*)-clear key(C) asterisk(*) machine will ask you to enter simulation enter (14) on 10 key pad press start,machine will reset or you may need to press CA key to make it reset. If problem comes back you will need to place a service call.
Posted on Aug 20, 2011
Help, fix the error code of Kiyocera Photocopy Machine "match the position of envelope switches"
Previous FIXYA question had two suggested answers:
http://www.fixya.com/support/t6209979-match_envelope_switches_error_message
match envelope switches error message cannot remove it cannot bypass it...
Quoting:
Open the back side of the printer. There are 2 buttons for the envelope. Switch them so that they are at the same position for normal paper. See also manual. It's described there. Posted on Sep 29, 2010
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts Posted on Sep 29, 2010
Aug 12, 2018 | The Computers & Internet
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
"match envelope switches" error message. cannot remove it. cannot bypass it. printer is unusable. urgent. already down one entire day, students (and myself) are climbing the walls. Thank you for any...
Sep 29, 2010 | Kyocera Office Equipment & Supplies
Having problem the machine showing E -1
yes it may be the lamp and also could be the thermal fuse within the lamp circuit and also could be the lens is not retuning correctly in home position or the mirrors in the back right to the lens also not in home position . try to take away the top glass , the black covers of the lens and switch on and check all these points.
if every thing is correctly located back the mach. will operate if error is still , ask the tech. to perform simulation 5-810
Jan 10, 2009 | Ricoh Aficio 450 Copier
Envelope feed problems
The problem is due to the type of envelope materials you are attempting to print on. The envelope stock (paper) is much too thin or lightweight. This is the primary cause of the wrinkling.
I would suggest that you switch to a heavier envelope material, but try to stay away from linen envelopes, as these will tend to wear down the fuser mechanism faster that normal. Most printers and copiers all have this classic problem.
I worked as a design engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times over and the only available solution is to change the stock. I (KMA) did work with a company in Canada who developed a specialized mass envelope feeder system for many of our systems. However they made major design changes to the feed mechanisms and feed roller pressure to deal with lighter stock materials.
Hope this information helps you out.
Cheers,
Keith
Oct 22, 2008 | Canon imageRUNNER 5020i Copier
Printing envelopes
If you look closely at the very front of the paper tray, just to the left of the sliding thing that keeps the paper from drifting out of the front, you will see a couple of illustrations showing how to position envelopes in the paper feeder. For regular letter-sized envelopes, or even greeting card envelopes, place them face down with the top of the envelope pointing to the left as you are facing the printer. The return address area should be away from you. Position the envelope all the way to the right side of the paper feeder, then gently slide the envelope all the way back until it is stops so that it is accessible by the paper feeder. Bear in mind that it will be flipped over when it comes out. To avoid wasting an envelope, do a trial print on a piece of paper to make sure you understand the positioning correctly. Good luck!
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
Open Questions:
22 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
