Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Posted on Sep 16, 2009
Top arm doesn't seams to spinning, and leaving food particals on dishes.
Posted on Nov 27, 2009
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Soap dish not opening during cycle
Contact service center for help. see whether the latch is free from friction. could be electrical fault also.
May 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap door wont open
I have replaced a dish washer soap dispenser once. Not hard to do. Need the make and model number. This dispenser is activated mechanically so there may be a broken latch or spring in the dispenser. Check the dispensers operation manually and see if it appears to be operating normally.
Jan 16, 2010 | Frigidaire FDBB1940D Dishwasher
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Our dishwasher won't release the soap during the cycle.
We discovered there was a dish blocking the soap dispenser during the cycle. Once moved over, the soap dispenser opened.
Dec 13, 2009 | Frigidaire Dishwashers
UNDISSOLVED SOAP RESIDUE AND
I have the same dishwasher and kept having soap still in the dispenser at the end of the wash. Someone mentioned this, but what was happening is that the soap dispenser lid was blocked from fully opening by the top rack. You also typically have large pans in this area, so the water spray is blocked from getting under the half open lid well. I started opening the dishwasher after I heard the dispenser latch release, so the lid could fully open. After that, I had no problem with soap still in the dispenser. I started setting a timer to open and shut the dishwasher door about 20 minutes into the wash process (after the latch had released for the 2nd wash cycle), so the soap dispenser lid would be fully open. This was a pain, but it worked. The other thing to be careful of with this dishwasher is to ensure you have pushed the top rack in tight before closing the door. Look at the water connection for the top "spinner" and you will see how the plastic pipe fits up to the supply. If you don't have the rack pushed in tight, you get leakage around the connection and don't get good water spray from the top spinner arms. This can definitely affect the quality of the wash. You mentioned the dispenser lid is open when the cycle is complete, but that is because once you open the door it can fully open.
Mar 26, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
729 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
