Question about Hitachi Televison & Video
My Hitachi 55 inch tv sound and screen went out. Model no. 49R80
    Habit-Forming:
    New Friend:
  • 123 Answers
Replace the main board. Parts on eBay or internet.
Posted on Sep 02, 2019
SOURCE:
dgjtex
  • 405 Answers
SOURCE: screen went black while watching, no sound
Almost for certain your power supply board is bad, Can be repaired at the component level only if you have some electronics savy! Good Luck!
Posted on Dec 26, 2008
SOURCE: hitachi 55 inch went black and standby light stays
Hope you already resolve it, if not, here what I went through 1. go to http://www.service-docs2.com or similar place to get a service manual for your model ($10-18) 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Posted on Jun 12, 2009
SOURCE: Black out?!?!?
I turned on my 55HDS69 a week ago and WAAH-BOOM, No more picture but the sound was fine. The resolution underway at a local repair shop is to replace the upper & lower buffers. The TV is 2 yrs and nine months old. I did not buy the extended warranty as I expected a $3000+ TV to last longer than 3 years especially since my house is like a climate controlled class 40 clean room and teh TV is not over used. The parts are ~$225, The labor is ~$225. Hitcahi would have sent the parts for free had I been within the 2-year window (1 yr regular warranty + 1 yr grace period). It was absolutely silly of me to think HITACHI would do the right thing and send me parts at 2 yrs and 9 months (sarcasm). I can tell you one thing......There is NFW I will ever buy a Hitachi product again and that includes anything even affiliated with Hitachi (inc. imbedded electronics). I will steer every person on the planet away from them in the future. My original plan was to ship the TV to the Hitachi CEO to make a point but the Hitachi folks don't deserve that kind of respect (Unless it blows out again) :(
Posted on Sep 02, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a hitachi model # 46f500 projection tv.
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection2.gif tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks2.gif with fins on them.
When the chips are installed a white grease called heat sink2.gif compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Nov 08, 2009
johnnydiode
  • 647 Answers
SOURCE: 55 inch hitachi lcd projection tv has yellow and
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses on one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and visually inspecting the lamp itself and the lens that it shines onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Have a tech confirm-Get an estimate -Be sure to vote/rate me if this helped Thanks!
Posted on Nov 24, 2009
Hitachi plasma p55t551 screen went blank but still power on n good sound
Any number of issues including power supply to main board are possible------Have you removed power from the set and or a box if used for a while?
Nov 05, 2012 | Hitachi 55HDS69 55 in. Plasma Television
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
The audio in Hitachi 62 in rear projection tv was intermittent and now it gone completely, I just replaced the Convergence chips because it had the 3D color separation ,i was able to fix that problem , now...
Model number 55VG825 IS NOT 62 INCH SET, IT IS 55 INCH DLP.
WHAT IS ACTUAL MODEL NUMBER OF YOUR TV?
I can give more information if you give me correct model number---if convergence is now working, it has nothing to do with sound unless you created the problem when you repaired it.
The more info you give me the better I can help you.
I am here to help people, I do this here for free.
SD TECH
Oct 31, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have been offered a 55 inch Hitachi Projection TV
Yes it is. A TV repair shop can replace the parts for less than $100.
Oct 22, 2009 | Televison & Video
Screen went black while watching, no sound
Dec 26, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
