My jackson avenger LT is not working. Power is on but when the start button is pushed machine does not operate.
2 Suggested Answers
SOURCE:
Jahn27
  • 1554 Answers
SOURCE: Clothes put in dryer, power
The dryer doesn't operate because the motor is not running and this is commonly caused by the blown thermal fuse which is located on the blower housing. This thermal fuse is wired in series with the motor and if it is blown open, power to the motor is cut and it will not run. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the other part (thermistor or cycling thermostat) on the blower housing if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 10, 2011
When I turn on my Jackson Delta 5 it says that it is heating water, and that is all it will do. It will set like that until I disconnect the thermostat wire and plug it back in. Then it will continue the...
THIS could be your huckleberry! It is item 3 of suspects...
Also note ITEM 7, "heater delay relay"?
Disconnecting and reconnecting MAY be resetting that relay!?
ALSO BE VERY AWARE OF THIS:
BEFORE the heater element can be energized, the rinse
booster heater MUST be initially filled with water. Damage to
the heater element will occur if the element is not submerged
in water!
Here's your thermostat:
Jackson 5930-003-13-65 THERMOSTAT,
120-170 DEGREE "WAS"
thermo-xpxypaj2co3qxlf13c0q1l2g-5-0.jpg Find it here:
Jackson 5930 003 13 65 THERMOSTAT 120 170 DEGREE WAS
$137.11 plus shipping
OR SAVE SOME LOOT AND GO HERE:
eBay: Jackson thermostat 5930-003-06-48 175-195F
Item location: Camano Island, Washington, United States
eBay:
122938835291
$129.50 INCLUDING SHIPPING!
Get your MANUAL here:
http://www.jacksonwws.com/wp-content/uploads/2016/08/Delta-5E-manual.pdf
text: 'TEMP WASH AND RINSE: 120 degrees'
>>> 140 degrees recommended for BOTH (see page 3). <<<
TROUBLESHOOTING on Page 16 and 17!
"Wash temperature not at required reading."
1. Check that white/blue wires are connected.
2. Defective thermometer.
3. Defective thermostat.
4. Rinse heater defective.
5. Defective heater contactor (R2).
6. Incoming inlet water temperature below required minimum. 7. Defective heater delay relay (R4)
See ANOTHER GREAT troubleshooting chart here!
http://kitchen.manualsonline.com/manuals/mfg/jackson/delta_5_d.html?p=21
$50 please... JUST KIDDING
Anthony
Feb 04, 2018 | Jackson Delta 5 Dishwasher
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Screen went blank. That was my initial problem. Upon restart, it would operate fine for a couple hours, then die again. The duration of operation rapidly became shorter and shorter. The laptop now will...
you are in luck as you have a video card that is replacable .. this is your video card : PCI-Express™ x16 graphics subsystem, featuring:
o
NVIDIA® GeForce™ Go 7900 GS with 256MB GDDR3
SDRAM VRAM
NVIDIA GeForce Go 7900 GS <<<<< go to web site and buy a new video card because if everything else works it should be your video card has died
May 15, 2017 | Toshiba Satellite P105-S9337 Notebook
I have a 1996 dodge avenger with trouble codes p1782 p1783 p1784. what are the exact problems with my tranny?
Battery voltage removed from TCM when the key is in the Run/Start position [car running]
Theory of Operation: A battery backed RAM (Random Access Memory) is used to maintain some learned values. When the battery B(+) is disconnected, the memory is lost. When the B(+) is restored, this memory loss is detected by the TCM. The code is set and the learned values are initialized to known constants or previously learned values from EEPROM. This results in the reinitialization of some parameters.
Transmission Effects: Loss of trouble code data. Immediate limp-in mode if power is lost while operating the vehicle. Normal operation is resumed if the power is restored during the same key start.
Possible Causes:
Battery voltage removed from TCM <--clean the battery terms
TCM disconnected .<---- check plug
Bad TCM ground circuit. ,<--check/clean grounds
Bad TCM
find the TCM here.. start with checking the battery
[img]http://ww2.justanswer.com/uploads/tsmodie/2009-09-18_193158_tcm.gif [/img]
Mar 12, 2010 | 1996 Dodge Avenger
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
1. Power it on
6. Power it off and on, again
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
New start button?
Hello Colette,
When a component sometimes works and sometimes doesn't work, it suggests the component itself is functioning correctly. Check for loose wire connections on the door switch, the start switch, and on the cycle-reset switch which is located on the cam-timer assy of the machine (if so equipped). Cam timer assy is behind the kick-plate, under the door.
Jun 25, 2008 | Jackson 24 in. JPX-300H Built-in...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
