Question about Dryers
Dryer will not shut off on its own
Roper REL4632BQ1
Dryer will not shut off on its own. We have replaced the timer on the unit but that didn't correct the problem. Prior to the dryer not shutting off while on low heat it would stop but the nob control would contiue to time through the fluff cycel.
  • 64 Answers
SOUNDS LIKE YOUR DRY SENSER IS BURNT OUT
Posted on Sep 14, 2009
No Heat, No Airflow
Need to replace the timer.
Dec 09, 2013 | Roper REX3614KW Electric Dryer
Roper dryer doesn't stop
Hi frank_kleins...
Sounds like your timer is faulty...replace, they are not rebuildable.
When you go to replace the timer, be sure to buy the same kind, and remove one wire at a time and replace one wire at a time that way you will not get confused with the replacement
Please rate me
Bud
Sep 28, 2012 | Roper RES7648E Dryer
I have Roper Dryer #RED 4340sq1 the dryer can run all day it will heat up the wash room , but the will not be dry. The timer will remain at the same setting, so I replaced the timer with a new one and I...
Okay so the timer is not advancing in any cycle? if so its a bad clock on the back of your timer I know you put a new timer in the unit but I have seen them brand new and something be broke out the box with parts. after that or if the timer advances in the timed dry cycle its definitely a venting problem or a power issue need to make sure the vent is installed correctly no more than a 90 degree bend in the pipe and you don't want the vent hose longer than 4 feet hope this helps. If it still not drying correctly I would recommend you having a qualified service technician come to your home and inspect it to save you some time and money but hope this helps.
Jan 22, 2011 | Roper Dryers
The timer control does not work. Dryer continues to run. The control timer does not advance dryer does shut by it self.
Open the top of the dryer and check to see if any wires have come off the timer. If they have not, then replace the timer. Below is a video and parts link you may need.
Video
Part
Hope this helps you!
Nov 23, 2010 | Roper REX4634KQ Electric Dryer
Timer not ticking,not starting
Hi. This will be the result of a failed timer motor. This mechanism is the main initiator of the unit. The unit will not operate properly, in this state. Proper current will not be directed correctly, due to the failed timer motor. The motor provide the forward advancement of the dial plate across the cogs. This is vital to optimal dryer functions.
The timer module must be replaced. Once replaced, the unit will return to its normal operating status.
NOTE_ Your door switch is not the culprit. The timer has failed.
Dec 14, 2009 | Roper REX4634KQ Electric Dryer
Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Mar 16, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont stop Timer wont work either Cycle
058aeba.jpgReplace the heating element if it is bad. if it is not then replace the high limits mounted on it at top and bottom
Sep 27, 2008 | Roper RES7646KQ Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
