Question about Compaq Computers & Internet
Battery backup problem - Compaq Computers & Internet
  • 86 Answers
Please clearify ur problem
& try 2 install Power Mgmt software
Posted on Sep 13, 2009
Testimonial: "my laptop bettry problem"
Where is the backup battery?
portable battery backup power supply for macbook pro and air
www.clubfidelis.com/news/index.php?q...battery-backup-power...air
PORTABLE BATTERY BACKUP POWER SUPPLY FOR MACBOOK PRO AND AIR: PORTABLE BATTERY BACKUP POWER SUPPLY ... HT201700 I need a portableback up battery for my MacBook Air 11 . ... air purifiers that controls mold.
Battery Powered Air Purifier - Wag.com
www.wag.com/html/sg/battery-powered-air-purifier.html
... 365-day return policy. Buy Battery Powered Air Purifier at Wag.com. ... MarinaBattery Operated Air Pump .... Penn-Plax Air-Pod Battery Back Up Air Pump.
Amazon.com - Mini Portable Battery Air Purifier Air Ionizer ...
amazon.com/exec/obidos/ASIN/.../amztowps-20
Amazon.com, Inc.Amazon.com - Mini Portable Battery Air Purifier Air Ionizer For Small Areas - BatteryOperated Air Purifier.
Jan 05, 2016 | Air Purifiers
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Short backup time
    Suspect battery failure/faulty cell in a batt
    Remove batts and check outside unit
    charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
    faulty one will be obvious.
    MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
    Check you manual for safety procedures, BEFORE working on Batteries.
    hope this helps
    thanks for using Fixya
    Jul 06, 2010 | Powerware 9120 UPS System
    Change the backup battery in MC9060
    Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
    Sep 23, 2009 | Symbol MC9090 Mobile Computer Portable...
    HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
    y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
    Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
    The battery backup is very low
    Looks like either the devices connected to the backup battery are consuming too much power than that backup can handle or the backup battery is getting worn-off. You may need to change the batteries or take-off some load (remove some devices that consume power) from the backup battery.
    Feb 03, 2009 | LG KU990 Viewty
    I'm getting a message - backup battery very low etc -
    you can buy a Backup battery for the axim X3 series on Ebay for about 17.00 that includes shipping. best price Ive seen
    Dec 05, 2008 | Dell Axim X3 Pocket PC
    Backup battery problem
    Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
    Sep 04, 2007 | Dell Axim X30 Pocket PC
    When should I replace my backup battery?
    The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
    Sep 14, 2005 | NEC MobilePro 900 Handheld
    Computers & Internet Logo
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
