Need video cable - Televison & Video
  • 3 Answers
Go to check sp road in bangalore all kind video cable there you see
Posted on Sep 13, 2009
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See http://www.svideo.com/scart2.html for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: http://www.retrevo.com/support/Akai-PDP4273M1-TVs-manual/id/741bh140/t/2/ . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Have got sound through all devices plugged in however no picture. Using video cable (Yellow) and red/ white audio. Have got yellow plugged in monitor out....
your video source (cable box or Blu-ray or satellite box) has to be plugged into a proper video (yellow) input on the Pioneer A/V receiver and you must select on the TV, the video input where the yellow video cable is plugged in from the Pioneer A/V receiver (use TV remote). Also select on the Pioneer which source component you want like the cable box or whatever. Check cables for quality. Swap RCA video cables to see if cable is bad. Try new video cables. May need to adjust a user setting on the Pioneer A/V receiver. Make sure cable box or whatever is plugged into the yellow video input for that component you are selecting on the Pioneer.
Mar 27, 2011 | Pioneer VSX520 Receiver
What are the red yellow and white cords for i have a xbox
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
Nov 22, 2010 | Sabrent USB-AVCPT Video Capture
Panasonic pv-gs15
You need 3 cables Yellow, (Video) + Red & White, (Audio L&R Stereo) Or Mini-DIN, for SVHS Video cable, this is ONLY for Video, Audio, is still Red & White. Or Component, where you have 3 Video Sockets, cables, Green, Red, Blue, All video, all color to color, both ends, and again Red & White for Audio. Sometimes there is FireWire, or HDMI you need a cable and the PC MUST also be equipped, You need software and drivers for FireWire, of HDMI..
Mar 26, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Problems with Audio and Video cable
there is a switch on the base of the cable labeled HDTV and TV, move to TV for normal cables.
Dec 06, 2009 | Microsoft Xbox 360 Console
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
What cable do i need to connect to tv
Any of the following 3 will work. S-Video ? Composite (Video) ? Audio (RCA) Information taken from: http://www4.shopping.com/xPF-Sony-CCD-TR748 images of S-Video cable and Composite/RCA cables listed below.
Jul 26, 2007 | Sony Handycam CCD-TR748 Camcorder
Connect TV to cable
Hi, if I understand you right, your TV has only one (1) input method and that is an S-Video and you would like to view regular TV or cable channels. Two possible ways of getting to watch: 1) Get yourself a TV Tuner that will accept antenna or cable input and whose Video output will be fed in to your S-Video. Normally (but not always) output is a yellow RCA jack but of course some would have S-Video output also. Then you would need a cable to conect the output of the tuner to the input of your TV. Cables also can be S-Video to S-Video or RCA to S-Video. Of course, you would need another RCA pair (stereo) to feed the audio to your amp for the sound. 2) Another is to use the built-in TV tuner of an old VCR. Same procedures follow. Hope this works out for your. Please let me know how it turns out. Cheers.
Apr 12, 2007 | Samsung TXK2567 TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
