Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My kodak printer esp3 is not printing it shows the tear drop symbol under the on/off button blinking read. What does that mean?
My power switch and the error button won't stop blinking on my Kodak printer.
my printer is not printing paper and the paper not insert the printer
Sep 29, 2012 | Kodak ESP3 AllInOne InkJet Printer
I own a kodak esp3 printer i replaced the ink cartridges and have faint lines going through the pictures what could be the problem?
Sounds like print heads are clogged and need replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Jan 11, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 printer will not connect with Windows 7
On June 8,2010 Kodak released a new driver for ESP3 printer.
Version 5.3.0 for Window 7
Download it HERE
Jul 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 not printing
Don't have a solution but can confirm this printer seems to be full of bugs. I have reinstalled software twice which gets the printer going for a very short time only. It does not recognise the Kodak ink cartridges..! Very frustrating.
Feb 27, 2010 | Kodak ESP 5 Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 installed 2 new cartridges black light
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can't get the clean out door back on from the Kodak ESP3.
Try to download the manual of your printer so that you can see the actual position of that Rear Access Cover at the back of the printer. This is the site..
www.kodak.com/go/manuals
And look for your printer.. Bu the way its a PDF file...
Aug 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Wont print pics
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Aug 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer 3 in one kodak esp3 the ink is full
upgrade the firmware of ur printer.go to kodak.com/go/printhead support.take out printhead and ink cartridges ,reseat them again.if problem still persists,call kodak @ 1800 421 6699. they will replace ur printhead free of cost
Jul 22, 2009 | Kodak 5300 All-in-One InkJet Printer
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
123 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
