Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
After the mower gets hot, it shuts down.
Mower may run for 10 minutes or 1hour, then shuts down. I checked the fuel supply, spark on the plug, so i think the coil is good. checked the hole in the fuel cap. I am gonna check the gap on the valves next.
    Sergeant:
    Champion:
  • 229 Answers
My john deere did the same thing i had spark and it did run,but the coil heated up an there was a short in it and it would stop and you wait awhile and it cool down and it would start again,i replaced the coil and the problem was gone.
Posted on Sep 14, 2009
Why does Mower cut off after running for a short period
Maybe some thing in the Carburetor or plugged fuel line? Worth a check
Jun 13, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs and Stratton needs primed to start when hot
sounds like the carby needs another clean out and did you blowout fuel tank and make sure you put fresh fuel in it not stuff that has been in your tin for more than a month
Feb 14, 2013 | Garden
Mower start fine. Runs for 20 min or so and then runs ruff and shuts down. Restarts fine and shuts down appr. 5 mins later. Has new spark plug,air filter, fuel filter and more than enough gas.
It's one of two things. My first thought is that you have a clogged gas cap. Try loosening it when the mower starts to run ruff. If it smooths out again and runs fine, then you know that the carburetor is not venting properly. Either buy a new gas cap or clear the breathing holes in the cap, if possible.
The only other thing it can be is that your Ignition Coil is going bad. A bad Coil, once it gets hot, will shut down. But it usually takes longer than 5 minutes for them to cool down well enough to start back up.
My Vote is the cap!
Good Luck!
Jim
Aug 18, 2011 | Poulan Garden
Four stoke mower. Mower starts and runs ok but after a short time (10-15 minutes) the engine stops as though it has run out of fuel. Fuel tap on, filter clean, new spark plug. After a few minutes you can...
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Dec 28, 2010 | Briggs & Stratton Garden
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
I have replaced the spark plug filters belt on my riding mower it will run for awhile then shut down. What do I need to check next or repair?
your carburator is gummed up. get some fuel additive called seafoam. Add it to your fuel and run your mower for a few minutes. this should clear your problem. if it doesnt you will need to rebuild the carburator. J.
Jul 04, 2010 | Garden
Where is the fuel filter on a Yardmachine Mod.#11A-41MY229? The mower has only about 36 hrs on it. It seems that its not getting enought fuel. could the carbon cannister have something to do with not...
There is no fuel filter, maybe a screen in the tank. Running good for 20 minutes then shuts down sounds like a coil getting hot then not sparking. Next time it quits check for spark.
Mar 14, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Crafstman riding mower cutting off now won't start at all
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
Oct 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower runs fine for about 10 minutes>
sounds fuel starvation check the filter or the vent into tank is causing a vacumn
Aug 12, 2009 | Craftsman Garden
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
855 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
