Question about Maytag Neptune MAH5500B Front Load Washer
Error code d5 on front load neptune washer - Maytag Neptune MAH5500B Front Load Washer
  • 220 Answers
D5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Posted on Sep 13, 2009
  • 28 Answers
Coin drop mechanism error see pqge 3-16 at this site
http://servicematters.com/maytag_library/docs/16022162.pdf
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
make sure it is installed correctly - there are 4 yellow plugs at the back that need to be taken out.
Posted on Jun 20, 2008
  • 50 Answers
SOURCE: how to fix the LO error code on Maytag Neptune front load washer
Not really bad news. The unit requires a door lock assembly.
Posted on Feb 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Posted on Nov 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Neptune MAH5500B Front Load Washer: what is the "LR" error on a Maytag Neptune washer...
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$#$%
Posted on Oct 01, 2010
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Showa error code d5 and won't do anthing at all??
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf Good luck, I hope this helped
Please rate me, Thanks
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Jun 14, 2008 | Maytag MAH8700A Front Load Washer
May 30, 2008 | Maytag MAH6700AWW Neptune Front-Load...
MAYTAG NEPTUNE
Not sure if you solved this one yet..but ...
d5 - Door is open during washing
I have some more codes for a Model # MAH6700AW if you need them.
Nov 04, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,698 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
