Question about Cell Phones
Where is the rear wiper water bottle placed on a bedford rascal van
Why no wiper fluid to rear wiper 2002 ford explorer
the washer pump for the rear window is located in the washer bottle under the hood that the front washer work out of. the pump may have stopped working and needs replacing. have someone operate the rear washers and listen at the washer bottle to see if you hear the motor working. if not then you will have to check the plug connection for the rear washer pump for corrosion, broken wires and power and grounds. if these check out ok then replace the rear washer pump in the bottle.
May 15, 2014 | Ford Explorer Cars & Trucks
Ime looking for a fuel pump for my Bedford/rascal/970cc
There are some BEDFORD Fuel Pumps for sale on EBAY.
Apr 08, 2013 | Cars & Trucks
The rear window wiper and window water spray will not turn off
This sounds like a bad switch, try dissconnecting the switch for the rear wipers and see if it stops if it does then replace the switch, the motor is pretty get and dry if it runs and the sprayers spray then it sounds like the switch is stuck or bad.start there,
Jul 20, 2010 | 1990 Plymouth Voyager
How can I check the fuse of the water pump for the rear wiper. the wiper move but no water coming out!
there are two pumps on the bottle one for the front and the other for the back. most likely the pump stopped working or something got in it and blocked the water flow. the pumps are at the bottom of the bottle. check them out first. they will be the same so you could switch them and see what happens. good luck
May 03, 2010 | 2000 Suzuki Grand Vitara
How do I refill the wiper fluid for rear window?
That van only has the one washer bottle. You fill the front bottle and there are two pumps inside that bottle. If you don't have any fluid coming out the back end then check to see if 1 the pump works. If you turn it on and it you hear the noise then the pump works. 2 check to make sure that the rear line has not popped of the one way valve at the back.(you can seee the one way valve if you remove the body to gate rubber). 3 check to see if there is anything plugging the lines or rear nozel
Nov 10, 2009 | 2000 Oldsmobile Silhouette
1998 Toyota Starlet - Windshield Washer not working......ideas?
the washer motor is gone then ,,,its in the bottle,,
May 08, 2009 | 1983 Toyota Starlet
Front widshield washer fromm 1999 Cherokee doesn't work
Your rear bottle for the wipers should be at the back of the vehicle.Look in back for removable panel and bottle should be there.Turn your ignition on(no start)and activate rear washer Listen for the sound of the motor
Nov 20, 2008 | 2000 Jeep Cherokee
WINDSHIELD WIPER FLUID WILL NOT COME OUT BUT WIPERS DO MOVE
the pump working? hoses cut or disconnected?
Oct 25, 2008 | 2003 BMW 5 Series
Windshield wipers
the wiper ball joint must have come of it happened to me you need a new arm joint and the motor must be blocked on the water bottle you will find the motors at the bottom of the water bottle
Aug 06, 2008 | 1997 Hyundai Accent
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
