Question about Clarion DB148R CD Player
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
  • 227 Answers
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Posted on Sep 13, 2009
My DB148r doesn't work at all after I change my battery, the mechanic think I will need a cod or something to start it again. But i lost the manual. Pleas help Karl
There should be no code for this radio. Check all of your fuses and make sure you are getting power to both the red and yellow wires if you can.
Apr 06, 2011 | Clarion DB148R CD Player
2004 sunfire ignition key wire does it have one/ instaling new radio only have constanyt 12 volt radio power on off button does not shut off do i use this wire and where does it go the ignition wire...
Hi, your factory Sunfire wire colors are pasted below. The yellow wire should be accessory. This should connect to the stereo's red power wire. The orange "always hot" wire should connect to the stereo yellow wire--this is only used to keep your station presets in memory. Please let me know if you have more questions, and thanks for using FixYa.
2004 Pontiac Sunfire Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 04, 2011 | 2004 Pontiac Sunfire
Unlock radio code
Assuming that you have the original Clarion radio, the code should have been provided by the original owner. If not, you might be able to get it from a Saab dealer by way of the VIN lookup.
Assuming you have the correct code (of four digits I believe), the entry drill is as follows:
  1. turn on the ignition,
  2. depress the radio power switch once,
  3. depress the DNR switch and keep it depressed throughout the rest of the procedure,
  4. key in your code number using the station preset keys (1 through 6)
  5. after last digit is entered, release the DNR switch and unit should operate
If you make an error entering the digits, simply release the DNT switch re-press it and start entering the digits from the beginning.
Dec 21, 2009 | 1991 Saab 900
I have lost the instructions for my car radio and need to enter the code after the battery went flat. It's a Clarion PN-9939U (CH916) fitted into an 1996 Nissan Almera. I have the code but no instructions...
Clarion PN9939U Nissan Code Entry
After switching on the set ' CODE IN ' will be displayed.
Press preset 1 and the set displays '0000'.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
To save the code press the [ ^ ] key. The set will now operate.
Nov 03, 2009 | Car Audio & Video
Interupting music by news bulletins
There should be a button or option for TA. Switch it off to avoid Traffic announcements and news.
Oct 13, 2009 | Clarion DB148R CD Player
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
Got a clarion db148r car stereo system but no wiring diagram. can you tell me the colour coding for the wiring?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate
Clarion drx9375r tuning radio
To change stations, make sure you are in radio mode(push the FUNC button in upper left corner), and move the 4-way button Left or right. To add station to presets, press and hold preset button until it is saved.
Nov 18, 2008 | Clarion DRX9375R
Clarion DB 148R
what is the pin diagram on the connector (left to right) (top to bottom) 1-15
Dec 25, 2007 | Clarion DB148R CD Player
Clarion DB148R CD Player Logo
210 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
