Question about Lexmark JetPrinter X1185 All-In-One InkJet
X1185 not scanning
My printer isn't scanning :S. Its been working fine since i got it a few years ago... I haven't used it in a while (about a month, maybe 2 at the most), I turned it on and went to scan something and it 'jammed'. The 'light' which scans the document and normally comes acroos and then back scannign it just gets stuck at the start and doesnt do anything and makes a sort of 'ticking time bomb' kinda noise is the best way i can describe it... the only way i can stop it is unplugging it at the back because truning the pwoer off does nothing...
Can anyone help? Can it be fixed or is it gooing to have to be dumped??
Re: x1185 not scanning
My scanner was working the other night then i went to scna another pic and the white strip in side was up and down and it turned and now it is side ways and it wont move and makes a weird sound when i go to to use my scanner
Posted on Feb 01, 2008
0 characters
3 Points
I have a Lexmark x1185 and it doesn't print anymore (It worked fine a few weeks ago). I can scan with it normally though. Basically, when I turn it on, the power button flashes... I already tried...
Hello. You might want to give it a fresh start by properly uninstalling it from your computer. To uninstall the software properly on Windows 7, go to Start Menu > Programs > Lexmark Series folder > Tools > Uninstall. Restart the pc. To reinstall, use this driver from the Lexmark website. Just click on the link: . Though it's a 64-bit Vista driver, it's the same driver used on Windows 7. Download and install the software.
Mar 11, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
Hello Barbhinkins,
Please find the vista driver for this printer at this link. Follow the instructions to install properly.
Hopefully this file will also have driver for scanner.
Aug 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I bought a Dymo label printer several months ago and just attempted to set it up for use. The ac adapter shows a blinking green light, however there is no light on the printer, and it does not appear that...
If you only purchased it a few months ago then why not return it...? They generally come with 3 year warranties, so unless you bought it 2nd hand you should be fine...
Nov 24, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
My Epson Stylus PHOTO RX500 will not print!
you may need to reset the printer that may help it if you dont have the software then call me back i and i will give it to you
Nov 29, 2008 | Epson Stylus Photo RX500 Printer
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x 1185 on windows vista
icannot conect my lexmark x1185 to my compaq vista
Jan 07, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark printer x1185
too often i have to download a driver for my printer because my pc runs on vista and my printer is a lexmark, it runs god for a couple of months and then it stops communicating with my pc.
Oct 07, 2007 | Lexmark Refurb X1185 All-in-One USB...
Lexmark JetPrinter X1185 All-In-One InkJet Logo
43 people viewed this question
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
