Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
The power in the house went off and now my TV will not turn on. I can't reach the power outlet due to the way the TV was mounted on the wall but I did shut off power to it for 2-3 minutes with no luck.
  • jaxlaw1999 Sep 13, 2009
    I agree that is appears to clearly be a power supply issue. Do these TV's not have any type of fuse that should protect the unit from this? While I am sure your recommendation is helpful, it clearly is not for a novice to do and would of course take days or weeks to get the manual and troubleshoot as you have suggested.
    Anything else, or should I just call a technician?
    President:
  • 1,462 Answers
You may have a power supply issue. What you need to do is to get the schematic for you TV. You can do this by calling the manufacture and asking for the service manual and the engineering diagrams for the TV. They will charge you but that is part of the cost of fixing these sets. After you have the schematic get a multimeter (you will need it to take voltage measurements
Now thru experence of 2 simular power supply units in the rear of the screen, I have found that in 2 cases that filter caps of 16 volt rating have swelled uo on top end and checked open or low capacitence and/or shorted. They appear to be under rated, voltage wise for the power supply.
On repacing the 16 volt rated caps with 35 volt rated caps fixed the probel..
Think this should help you
RATE THIS SOLUTION!
RNJ VINOD KUMAR .
Posted on Sep 13, 2009
  • Vinod Kumar
    Vinod Kumar Sep 13, 2009
    Even if its in case of problem with simple fuses all the fuses are present in the power supply, so any way you need to call the Service Technician to open and replace the fuses...sInce extra care must be taken in opening and handling the power supply unit
    RATE THIS SOLUTION
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Samsung ln32c450e1d no power at all
Ensure there is power in the outlet you have connected the TV and it has the rated voltage. If possible take the TV to another place, where you are sure there is power. If it does not work, this might need attention by a qualified service technician.
Aug 11, 2012 | Samsung Televison & Video
Why does our TV go through the channell setup everytime we turn it on?
Hi Mary -
The first thing you should do is consult the set up procedures on Page 8 / Section 4 of the manual. This will assure that you have completed and exited this important section properly.
If the TV should lose power (power outage, blown fuse or circuit breaker, cord removed from the outlet, etc.) the TV will likely need to have the setup performed when powered again for the first time. Likewise, a TV that is plugged into an outlet controlled by a switch, will lose power when the switch position is changed. Since switched and un-switched wall outlets look the same, you will need to unplug the TV and plug in a table lamp or similar and operate switches to see if it goes out. You will need to try both the upper and lower outlets as they can be operated independently of each other. If you find that the outlet is switched, you will either have to stop using the switch or find another un-switched outlet to power the TV.
I didn't see it mentioned in the manual, but some TVs have a dedicated power and a dedicated on / off button. If the power button is set to off, the TV will shut off and the remote will not be able to turn the TV back on until the power button is turned back on. The on / off button on the TV allows the TV to be turned on and off with the remote - or the on / off button on the TV. Again, this will only work if the dedicated power button is on. If the power button is set to off, it may be causing the TV to lose the set up information - requiring that it be done again. Make sure that you are using the remote to turn the TV on and off - or the correct button on the TV if you do not have a remote.
If all fails, you might want to contact Sanyo directly. According to the manual, they can be reached at 800-877-5032. I hope this helps & good luck!
Jul 31, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
I have a TH-42PX80U. The picture went black and the red light does NOT blink. I tried a different power cord in a different outlet and still won't turn on.
More likely to have power supply module failure, that will be the first place to look.
Most common failures in PLASMA TV are due to bad power supply module, Z and Y Sustain modules.
Dec 23, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Sony KDF- 42WE655 Blinks 5 times No picture or sound
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
Aug 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
